OUTLOOK EXPRESS I CAN SEND MAILS FROM MY OUTLOOK EXPRESS. BUT COULD NOT ABLE TO RECIEVE MAILS ON OE.The host ' * .com' could not be found. Please verify that you have entered the server name correctly. Account:* . *.com ', Server: mail. * .com', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 11001, Error Number: 0x800CCC0D
  • kbsrose Apr 05, 2008
    Thank You
    Genius:
  • 1,142 Answers
U need to reconfigure your outlook mail account as the incoming and out going server names are causing a problem.if possible plz specify me with the isp name from wich u have subscribed a connection
also u can contact ur internet sc provider for the same..they can help u to reconfigure the account....
Posted on Mar 28, 2008
Outlook Express error.Please suggest me how to stop it.
Hi, when did this problem first occur? I would suggest checking with the email service provider to see if they have updated any of their IMAP / POP settings that you also would therefore ve required to update, also verify your password is correct etc. would you like me to help with this?
Apr 26, 2016 | Computers & Internet
I can recieve e-mails but can not send e-mails how come
Depends on you smtp settings for the server. For instance, all variants which use mail.com would user TLS authentication and an outgoing server of 465 or 587. You'd have to check with the email server to verify their settings. (Gmail also uses 465, by the way.)
Aug 05, 2014 | Microsoft Outlook Express
When am sending mails from outlook express am getting this error"The host 'abcd' could not be found. Please verify that you have entered the server name correctly. Account: 'abcd',...
You'll need to go to your email through a browser (gmail.com or whatever you use), go to "Settings" or "Preferences" and the go to SMTP/IMAP Settings. From there it will give you instructions how to setup outlook or any other email client to work.
It seems like your outgoing mail server settings are incorrect, follow the instuctions from the email page and it should fix you up!
Hope this helps!
Jul 19, 2011 | Computers & Internet
Let our Experts solve your "I am having a Static IP for Outgoing E Mails in Outlook Express But I can t configure with that IP" and can't send Outgoing E-Mails in Outlook Express. Kindly tell me the...
email.about.com/od/outlookexpresstips/qt/et062406.htm
you can print the path needed to send mail
also you must use Internet Explorer to send mail in Outlook, if you use another search engine, it will not work.
Jun 05, 2009 | Microsoft Outlook Express
Outlook express
hi,
Error 0x800c0133 when you are retrieving email with your Outlook Express (OE) is because of currupted Inbox file.
To remedy please follow these steps:
  1. Open OE, on the left pane, right click "Local Folders", select "New Folder...", specify a name for your new folder as "Temp".
  2. If you are still able to access "Inbox", move all mails in "Inbox" to the new "Temp" folder.
  3. Go to menu "Tools" -> "Options" -> "Maintenance" tab -> "Store Folder" button. It will show the location of your Inbox file, please remember this location.
  4. Close OE, go to the location mentioned above, delete the file "inbox.dbx".
  5. Restart OE, the "Inbox" folder should be auto recreated. Move back your mails to the new "Inbox", remove the "Temp" folder.
or
Another solution
Error Number:0x800c0133
Error Number: 0x800C0133 = a corrupt Inbox.
Move any mail you wish to save to a local folder you create. Then:
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Press the Tab key to highlight the folder
location, then Ctrl+C. Close OE, then Start | Run | Ctrl+V will put the
location in the box - Click OK and you'll see the OE files. Otherwise, write
the location down and navigate to it in Windows Explorer.
In WinXP, Win2K & Win2K3 the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Windows Explorer, you must enable
Show Hidden Files and Folders under Start | Control Panel | Folder Options |
View.
With OE closed, find the DBX file for the folder in question {Inbox.dbx} and
delete it. A new one will be created automatically when you open OE.
General precautions for Outlook Express:
Do not archive mail in default OE folders. They will eventually become
corrupt. Create your own user defined folders for storing mail and move your
mail to them. Empty Deleted Items folder regularly. Keep user created
folders under 100MB, and Default folders as empty as is feasible.
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
Turn off e-mail scanning in your anti-virus program. It is a redundant layer
of protection that eats up CPUs and causes a multitude of problems such as
time-outs and account setting changes. Your up-to-date A/V program will
continue to protect you sufficiently. For more, see:
http://www.oehelp.com/OETips.aspx#3
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked.
Apr 16, 2009 | Microsoft Windows XP Home Edition
OE error says host pop3 cannot be found
hi
Can you reinstall the Outlook express may solve this issue. I do remember recently Microsoft released some new patches for Outlook Express may resolve this issue
good luck it might help u out .....
Jan 30, 2009 | Microsoft Outlook Express
POP3 CAN'T SEND USING THIS ??
hi...unless you've configured your email client (outlook, outlook express, etc)to use pop3 and smtp you wont be able to use this method for sending mails.....
aol acounts need to be configured for pop3 and smtp as do hotmail and gmail...each service has unique server names and there are pro's and cons to setting it up....your service provider will have the details of pop and smtp servers....a way round this would be to open your email and create new message and copy/paste the details you need into the new mail
Jan 07, 2009 | Dell Inspiron 1501 Notebook
Outlook Express :
Make sure that you check "remember my password" box when you configure your OE. It means it will not ask you for your password anymore every time you sign to your OE.
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
300 people viewed this question
David Payne
David Payne
