Question about Samsung SGH-D980 Cell Phone
Reset phone - Samsung SGH-D980 Cell Phone
  • 3 Answers
Codes are the best process to unlock, secret with the mobiles...I got my mobile codes from here http://www.superunlockcodes.com/ - Super Unlock Codes @ lowest costs.. Also in here we can get all GSM mobile codes...
Posted on Aug 25, 2010
    President:
  • 524 Answers
Samsung Secret Codes
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
Samsung Secret Codes Part 2
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
Samsung Secret Codes Part 3
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Posted on Jun 03, 2010
Reset my phone
Hello. what kind of reset are you asking for your phone? What is the exact model of your cell phone?
There are various types of reset such as soft reset, hard reset and master reset, etc., The procedure to reset a phone also differs according to every phone model. For example, if you want to master reset a Nokia phone, you need to enter its master reset code. You can get the master reset code for certain basic model Nokia phones from Unlocking4Free.com for free. Hope it may be useful for you.
Jan 27, 2015 | Cell Phones
Tip
How To Reset Your HTC Hero
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Turn off the phone, if you can.</li> <li>Remove the battery and wait 1 minute.</li> <li>Reinstall battery and turn on the phone.<br /></li></ol><span style="font-weight: bold;">Hard Reset/Factory Reset</span><br /><span>Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state.<br /></span><span> <ol> <li>Press HOME &gt; MENU, and then tap <b>Settings &gt; Security &gt; Factory data reset</b>.</li> <li>On the Factory data reset screen, tap <b>Reset phone</b>, and then tap <b>Erase everything</b>.</li> <li>Your phone will erase all personal data and restart. It may take a few minutes for the process to complete.</li></ol></span>or<br /> <ol> <li><span>When the phone is turned off, press and hold the <span style="font-weight: bold;">HOME</span>, <span style="font-weight: bold;">END CALL/POWER</span>, and <span style="font-weight: bold;">BACK</span> buttons.</span></li> <li><span>The reset process will start after a few seconds.</span></li> <li><span>When the phone finishes the reset process, press <span style="font-weight: bold;">MENU</span>.</span></li></ol><a href="http://www.htc.com/us/support/hero-sprint/help/tips-and-tricks"><br />Click here for other Tips and Tricks for the HTC Hero.</a><br />
on Feb 15, 2011 | HTC Hero Smartphone
What is the reset code of nokia
What is Nokia Phone model?You can reset the Phone easily using the master reset code.you can get the master reset code for old NOKIA DCT phones at Theunlockspot.com and reset from security lock.You can also get the master reset code for Alcatel Old Phones here..Try default code for Nokia Phones 1234 or 0000 if these codes not work means get mater reset code and reset it.
May 14, 2012 | Nokia Cell Phones
How do I reset my verizon htc innovation phone.
Resetting the phone will delete all data in it including your downloaded applications, and will resets the phone back to its initial state.
Press Home > Menu, then tap Settings > Security > Factory data reset.
On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the Volume Down + Send + End buttons. The reset process will start after a few seconds.
Jan 25, 2012 | Samsung Computers & Internet
I can't remember my security code. How can i reset it?
My nokia 2700c model.my problem I don't know phone reset code.please halpe me show my phone reset code
Sep 14, 2011 | Cell Phones
Phone pin code and spker is not working
try resetting your phone. you can try resetting your phone through codes. its the safe way to reset your phone. because when you reset your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you reset through codes. thats y i prefer this method to reset my phone. i got the codes from this site Unlock-free.com to reset my phone. try it
Aug 27, 2011 | Cell Phones
My phone is locked an i fogot my code
What is Mobile Phone brand and Model? You can reset the Phone using the master reset code,You can get the master reset code from here Prounlocking.com and reset the Phone,If the Phone is Nokia or alcatel means You can reset the Phone using the Master reset code. Before getting the reset code try 0000 or 1234 as default code it's for Nokia,IT not work means get the code from there and reset it.
Have put a code in to lock my phone and forgot it
Try master reset code from service provider and reset it...
Forget phone lock
you need to reset your phone. you can try resetting your phone through codes. its the safe way to reset your phone. because when you reset your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you reset through codes. thats y i prefer this method to reset my phone. i got the codes from this site Wickedunlock.com to reset my phone. try it
Aug 19, 2011 | Cell Phones
Can not remove application
To perform a master hard reset on your Nokia E63 cell phone reset. The instructions do this is quite simple and effective on your Nokia E63 cell phone reset. Nokia reset. Master reset. you will need to:
On your Nokia E63 Dial *#7370# and then enter your master reset code, by default it is 12345
NOTE: Performing a Master reset on any Cell phone will master reset your Nokia cell phone and erase the nokia phone reset completely including contacts, pictures, videos etc. A hard reset on your Nokia cell phone E63 will remove any viruses you may have on your Nokia E63 cell phone master reset
This is a good way to reset your phone if it has any bugs in it that the updates don't fix. Remember to save any contacts or important pictures with the PC Suite. I didn't really know what PC suite was before, but it's a program from Nokia that you install on your PC. Using that and the data cable, you can backup important info or settings on your phone.
Mar 26, 2011 | Nokia E63 Cell Phone
Samsung SGH-D980 Cell Phone Logo
1,992 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
