Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
HP Officejet Pro 8500 a909 - Printer will not print - error message show majenta ink cartridge empty. Computer, in HP Solutions, shows majenta empty. Printer screen show majenta cartridge full. every several minutes recieve message on computer showing printer will not print because of the majenta cartridge is empty. I have replaced the cartridge and the same result. It did print a couple of pages and then went back to the same problem. Thanx.
SOURCE: Black ink stopped printing
Did you solve this problem, the exact same thing has happened with mine?!?
Posted on Mar 11, 2008
hamidquddus
  • 45 Answers
SOURCE: I just bought Officejet Pro 8500 A909. Installed
first of all disconnect the power cable from the back of the printer
press and hold the power button for 20-30 seconds
reconnect the power cable turn onn the printer
if you still get the same mesage , follow the steps mentioned in the URL below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01624398&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
if still it does not work call hp your printer is in warranty and they will replace the unit for you........................... hope this works .............thank you (HAMID)
Posted on Oct 29, 2009
pineworks
  • 4041 Answers
SOURCE: This is for an HP Photosmart 3310 all in one. The
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Jan 25, 2010
SOURCE: HP OfficeJet Pro 8500 A909 does not print
i cant print what happening. Its telling me to load paper but i have paper in slot. This started happening after a paper jam.
Posted on Feb 08, 2010
  • 5341 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
Printer error message
Is this an OEM ink jet cartridge -meaning was it made by HP and not a refill. There is a microchip on the ink cartridge that the printer logs how many times it has used that cartridge and how many times the print head is cleaned. If this chip gets dirty or if the mating side has ink or paper dust on that side you can clean it with isopropyl alcohol. If it was a refill or a generic cartridge the chip might not be programmed or it is dead. There is no sensor that detects how much ink is in a cartridge.
Mar 29, 2014 | HP Office Equipment & Supplies
I refilled HP 8500 cartridge but printer (Officejet Pro still thinks cartridge is empty. How do I reset ink level?
This model printer may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 03, 2013 | HP Officejet Pro 8500 All-in-one -...
I put in a new black cartridge, but the note keeps coming up to replace the empty cartridge. Then it goes to "cancelling allignment". When that is done, I'm right back to the empty cartridge...
At a guess I would think you have the wrong cartridge?
I had a 8500. Decided to upgrade to the A909 Wireless.
Having keep my supply of replacement 8500 catridges used to replace empty, that's when it came to light. Though similar, the chip it set up for A909 wireless printer.
It is a little known fact, if you are not careful when ordering, buying for the 8500 there are "TWO" seperate cartridges specs. Yes I was caught.
When puchasing make sure it is "WIRELESS" .
The non wireless 8500 usb cartridge yes fits but as you have found out fails to be recognized.
HP are naughty but then its all profit for them.
This is the most likely solution.
Mar 07, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have an HP Officejet Pro 8500 all in one printer. My magenta doesn't print. I can't print anything with red/pink in it. Can you help?
Try another cartridge first, making sure it is located properly in its seating and is the right spec.
You may not know, 8500 non wireless cartrigdes do not work in wireless A909.
Are you talking about replacing the cartridge at the left side front cartridge compartment or the printer heads under the scanner lid?
Feb 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer said it was out of one of the inks...I replaced it and it still shows it is empty. I looked inside and it appears to have leaked in from the cartridge into the printer. The cartridge is still...
You may have bought the wrong replacements.
You have to ask for "WIRELESS" A909
Shops are not always aware the the 8500 usb non wireless cartridge chip is not compatible with the Wireless A909 They are exactly the same cartridge but crafty HP change the chip specs.
Sorry, yes they caught me to.
Peter.
Feb 02, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I just bought a brand new HP 8500A all in one printer and it printed out a test page during the calibration/installation stage of the setup and after installation it now says install cartridges. I have...
There's good chance they are not the right ones.
Shop assistants are not all that keyed up on their products.
The 8500 Non Wireless Cartridges will "NOT" work in the A909 Wireless.
Yes they look the same and yes they will fit in the compartment, the "CHIP" is differant.
Good old HP.
Shop around online for cheap suppliers but make sure you only buy HP A909 Cartridges.
Peter.
Jan 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I've gone through the correct steps to change the ink cartridge and it still tells me to replace it.
I would make a guess you have the wrong cartridge!!
You must be sure to purchase HP A909 Wireless Cartridges.
If you have been sold the 8500 Non Wireless Cartridge (s) they will not work in the Wireless. The Chip is setup to malfunction. They are not interchangable.
Jan 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How to refill the cartridge
This printer takes the HP 940 cartridge. I own a Cartridge World ink refilling store and we cannot refill these cartridges yet. There is a chip on the cartridge that estimates the ink levels and shuts off the cartridge when it thinks it is empty. Any refills you find are either violating patent law with replacement chips or they are telling you to take the chip off your old cartridge and put it on the new one. This second scenario is a rip off because once the chip says the cartridge is empty, no matter how much ink is left, it will refuse to print.
Jan 31, 2010 | HP LaserJet 8500 Color Printer
HP OfficeJet Pro 8500 A909 does not print wirelessly from my MacBook Pro with OS 10.6.2 (Snow Leopard). How can I get it to print wirelessly?
Jan 07, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Oct 29, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
244 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
