Question about Viking 36 in Designer Series Freestanding Counter Depth Bottom-Mount Refrigerator - DDBF036
Ice build up in viking bottom drawer freezer
My viking freezer keeps develping ice behind the panel. how can i fix this?
5 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 21, 2008
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Posted on Apr 02, 2009
woodchuck789
  • 4070 Answers
SOURCE: Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 05, 2009
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Ice acumlating in bottom of freezer drawers..ice build up...icing up products in freezer, and keeping the drawer from closing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Viking DFBB363 Bottom Freezer Refrigerator
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Eaton viking imperial fridge keeps making ice build upin grate in bottom of freezer how do i fix this problem
the return air ducts are freezing up, unplug unit and use a hairdryer to defrost the entire freezer compartment
this will take a couple of hours to completely thaw the ducts
the ducts are behind the rear panel in the bottom
Nov 02, 2009 | Refrigerators
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
  • possible causes:
Mike
Jul 21, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Viking 36 in Designer Series Freestanding Counter Depth Bottom-Mount Refrigerator - DDBF036 Logo
103 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
