Hi. Download the latest BIOS from www.support.dell.com and follow the instructions carefully. If the system still doesn't charge the battery, it's either you have a dead battery or the motherboard needs replacement.
^_^
Posted on Jun 05, 2010
SOURCE: dell inspiron 1525(laptop) for windows Server 2003 drivers.
satish,
goto the dell website , and locate drivers for your laptop .. i have looked but only vista and xp are available , however
u could use the XP drivers ..
http://support.euro.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WW1&hidlang=DU&TabIndex=
Posted on Jan 14, 2009
SOURCE: Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Posted on Jun 08, 2009
SOURCE: battery wont charge and getting error 0148
0148 error is IDE ERROR: status (x) (s)
This
could be a problem with the BIOS, restart the PC and hit F2 as it
starts up, this will take you into the bios, reset the bios to default
setting, press F10, save and exit the bios, the PC will restart so
perform another check and see if the same error code return.
Posted on Jun 25, 2009
SOURCE: battery of laptop not charging
If the laptop works when plugged in, the power supply is OK. The battery controller is probably the problem, which would mean replacing the battery.
Posted on Apr 17, 2010
SOURCE: dell inspiron 1525 battery not charging
1)Reason:
a.The battery has no voltage.
b.There is problem with charger,
as it has no output electric current.
c.Low charging efficiency due to
external cause.
2)Solutions:
a.Test whether the charger has voltage and
output electric current or not.
b.Check if the charger is well contacted with
battery.
c.Activate the battery with voltage and current 1.5 time higher then
the highest ones of battery. (Use this method only when the battery can't be
charged.)
source from laptop battery site:http://www.buy-battery.ca/faq.htm
you can buy replacement Dell inspiron 1525 Battery there:)
Posted on May 27, 2010
Jul 28, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Jan 14, 2011 | Dell Inspiron 1525 Laptop Jet Black
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
May 10, 2010 | Computers & Internet
Apr 21, 2010 | Dell Inspiron 1525 Laptop
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Feb 03, 2010 | Dell Inspiron 1525 Notebook
Aug 04, 2009 | Dell Inspiron 1525 Notebook
May 17, 2009 | Dell Inspiron 1525 Laptop
Apr 22, 2009 | Dell Inspiron 1501 Notebook
196 people viewed this question
have you tried to perfrom power drain? you can do this by turning the computer off and you need to take out the battery then unplug the power adapater. Press and hold the power button for 30 secs. Put the battery back in and plug in the power adapter then power up the computer.
