Question about Garmin StreetPilot 2720 GPS Receiver
My garmir street pilot 2720 is not powering up. what to look @ first
  • 503 Answers
In order
1- Check using another device the power outlet
2- Check the garmins power cord, are the connections still firm, if they are loose and sloppy, bend the metal tangs out a LITTLE bit
also note the metal tangs in the power outlet may be bent in from continued use bend them into towards the centre of the plug NOTE PULL THE RIGHT FUSE ON THE VEHICLE BEFORE BENDING OR STICKING ANYTHING INTO THE HOLE TO ADJUST THE TANGS
3- In the end that you plug into the cars power outlet is a 1 amp fuse, is this still good.
4- Does it work in somebody else's car
Posted on May 10, 2010
I have a garmin street pilot 2720 I bought a garmin nuMaps lifetime product to up date, would like to up date for the 2nd time can't find where to go about this, I have the product key and the...
Log into your account at www.garmin.com by using the myGarmin link.
With the unit connected to the computer go to the myDashboard link.
Your Street Pilot 2720 should show up on the dashboard.
From there you should be able to apply the update.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 27, 2011 | Garmin StreetPilot 2720 GPS Receiver
What is the Pin-out for the power connector fro garmon 1490T? I have an AC adapter (120 VAC input 12VDC @ 500ma output) from my Garmin Street Pilot 2720. Can I splice on a mini USB connector on it in...
Hello gmonai,
Maybe this will help you some. I have found you the complete manual which covers most of the models of the Garmin Nuvi. It is the full manual from start to finish with complete operating procedures as well as schematics, operation instructions complete with pictures, and trouble shooting section and even other contact numbers to deal direct with Garmin, if your model is not covered in this manual.
Here is the link for you:
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Also if you can, please rate my solution if you can and some kind words would be appreciated. I also took the liberty to put my link at the bottom of this page that directs you to my personal page for all my areas of expertize, such as Automotive, Appliance, Electronics. Feel free to check it out anytime and save my link for future problem. Thanks So, Much Mike.
http://beta.fixya.com/users/mc1bean
Aug 13, 2011 | Garmin nuvi 1490T GPS Receiver
Unable to update unit
When you plug in the USB cable, if your System, Hardware, Device Manager lists "GARMIN Devices", then the problem has to be in your network connection or Garmin WebUpdater. If your Device Manager doesn't list "GARMIN Devices" then the problem is in the computer, USB cable, or 2720.
I have three 2720s right now with bad USB ports. I'm going to try replacing the USB driver chip in each unit, but now I'm just guessing. Hope this helps. Tom
Dec 30, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
2720 street pilot replacement
The screens are not interchangeable. The 2610 screen is 3.3x1.7" and is 305x160 resolution. The 2720 is the exact same size but 454x240 resolution.
Jan 13, 2008 | Garmin 010-00358-00 GPS Receiver
GARMIN STREET PILOT 2720
Is the power connector fully seated on the GPS unit?
Dec 11, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin Streetpilot 2720
I fixed my C530 on my own. Garmin support will not give you this solution.
I attached the GPS to the computer with the usb cable. I used the file explorer in windows to view the file system on the GPS. I sorted the files by date. Then I moved the files that had a newer date than the last time the GPS worked, to an backup folder on my computer in case I need to restore the files to the GPS again. I than disconnected the GPS from the computer and restarted the GPS. The GPS works perfect now and doesn't enter the demo mode any longer.
Oct 08, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
210 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
