Question about Konica Minolta Office Equipment & Supplies
HOW DO YOU CHANGE A CLEANING BLADE IN A CF900 COPIER
  • Konica Minolta Master
  • 1,297 Answers
Remove the OPC drum unit,remove the OPC drom and change the cleaning blade(fixed 2 screws).Normally if you change the OPC drum change automatically the OPC cleaning blade.
Posted on Jun 05, 2010
Service manual
Clean or change the drum cleaning blade,check the fuser unit rollers abd the transport belts.Clean the image transfer/separator coronas unit,check ,clean or change the drum antisplit bade,located under drum cleaning blade.
Apr 30, 2013 | Minolta EP1083 CS/PRO Copier
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
Print copy white
If the copies is whitw possible causes:
toner empty,not toner
developer drive transmission mechanism failure
image transfer current terminal poor intact
Feb 09, 2013 | Ricoh Aficio 2035 Copier
Dear sir my km copier have problem with the image.one side of the image is lighter than other side .i change therum cleaning blade but no result
The cleaning blade just keeps the drum clean. Is the copier on a level surface ? The toner can slide to one side if not. The machine also has a charge wire in the drum unit that needs to be cleaned. To clean it there should be a blue handle that you will pull toward you and then push back into place. Try that and good luck.
Jan 29, 2011 | Kyocera KM-1510 Copier
How do you change the cleaning blade and drum in Canon 5000 copier.
why do you want to change the drum, the drum goes about 5 000 000 copies and its too expensive.
The drum cleaning blade goes about 150 000 copies and to change him on your own you need service manual.
For service manual write me on emma.servis@gmail.com
Sep 18, 2010 | Canon imageRUNNER 5000 Copier
In a4 copy front and rear some border line not appear.physically image shift belt have no damage
Clean the OPC drum cleaning blade assembly or change the cleaning blade and the drum,if make more 40000 copies.
Apr 23, 2010 | Minolta C250 Color Copier
Need to change cleaner blade on drum
Remove drum unit, remove Drum, remove blade (2 screws)
** coat the new blade with some toner, or it will flip, when the drum start to turn, due to the friction. And always manually rotate it yourself prior to re-installation to make sure it is ok
Apr 28, 2009 | Canon C330D Copier
Minolta CF900
try and locate botton called ACCESS.on the OP Panel should be pressed after you enter you access code
hope that help ...if not try the START BOTTON
Jan 11, 2009 | Konica Minolta DiALTA CF910 Copier
Minolta CF900 code C3250
Description:
Intermittent C-3250, C-0210, or C-0230 codes occur during pre-drive.
Solution:
CAUSE: Worn mylar.
SOLUTION: Refers to the transfer drum joint Mylar.
SOLUTION: Replace the mylar (P/N 1144-4511-02)
hope that help
Oct 20, 2008 | Minolta EP1031/1031F CS/PRO Copier
Minolta CF900 error code C0030
The C0030 is referenced to the developer drive motor for the 4 developer units.
you may need to replace parts.
BUT check the oporation of the unit FIRST. LOOK BINDING IN THE DRIVE UNIT
HOPE THAT HELP
Feb 15, 2008 | Minolta EP1031/1031F CS/PRO Copier
103 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
