Question about Canon ImageRunner 2020i Copier
Display screen is blue wont turn on canon image runner 2020i
  • 1,219 Answers
In most cases is that system software is colapsed. The problem is when you turn on copier nothing happens with machine or display and you cannot copy or print.
Upload the system software, language,... for this you need service support tool, so call service.
Pls. rate
Posted on May 11, 2010
I have a Canon Image Runner 3320i copier and it has an error code E602-0001. Could you please tell me what that means?
e602-001/002/003/004 solution is turn off the machine after than
1-9 key hold & machine on 1 hour raning after same time display sow the downlod mode thn machine off/on
Jan 14, 2011 | Canon Image Runner 3320I Copier
Our office has a Cannon Image Runner 2020i and we are having issues with the scanner. Before today, it was scanning perfectly and sending the documents directly to our email. However, today, we can scan a...
Try to stop the copier and restart it, maybe it's something stuck in memory
Click the button stanbay more than three seconds and you will have a shutdown button on the display. After shutdown, remove the power cord, leave it a few seconds and put it back on, start the copier button, let me know if the problem persists
Dec 16, 2010 | Canon imageRUNNER 2020i Black and White...
I have a Cannon 2020i Image Runner, we had thunder storms over the weekend with power interruptions. Came in today and copier will not power on. I have confirmed the receptacle is live, is there a...
You need to remove the back cover and on power supply pcb there must be fuse. I belive glass fuse 5X20mm, not sure for how much A.
For service manual and board circuit send me mail on emma.servis@gmail.com
Sep 07, 2010 | Canon ImageRunner 2020i Copier
My Cannon Imagine Runner 2020i is sending faxes fine but isn't receiving faxes at all.
Could be a phone line problem, may not be set for English in the service mode. There could be another device on the phone line. Dial the fax and see if you here it responding. Plug a phone in the fax wall socket and call someone and be sure both of you can here each other clearly.
Mar 09, 2010 | Canon ImageRunner 2020i Copier
Canon 2020i during warm up display stays blue for about 45 minutes then just turns on. is it a bad display board
its either the template it sits on is going bad... the board that powers it is going bad... it has bad grounding or the main board is bad... check for lose cables... on the board.. and check to see if the voltage on the wall is stable and if there is any voltage on the ground for the wall outlet... if there is any voltage problems in the wall... switch to another outlet and try again... if same problem.. and if it were me.. I would reseat all cables try again... if same result I would by the lcd that the display template sits on... and if that doesn't work then I would by a display copier card....
Dec 16, 2009 | Canon ImageRunner 2020i Copier
Canon image RUNNER 2020i is flashing Error code E000808 after trying to print labels...what's up???
E808 A fault in the fixing drive circuit or the power supply unit is
detected
check the fixing rollers maybe some adhesive materials left on the roller and cause the fixing roller not to rotate smoothly. or some drive gears broke during printing on heavy media
Jul 02, 2009 | Canon ImageRunner 2020i Copier
Faxing with the Canon 3570 Image Runner
On the copier display screen is their a tab that says "send"? If not then you do not have the fax option installed. If you have the machine on your network, find out the IP address assigned to the machine and enter the IP address in the address bar of your Internet Explorer browser to access the machine settings from your PC. If you have a fax option you should be able to set it up from there.
Printdoctor
Dec 17, 2008 | Canon imageRUNNER 3570 Copier
ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Mar 12, 2008 | Canon USA - COPIERS - ImageRUNNER 2010F...
Canon Image runner 1670F will NOT receive faxes
scroll through menu and look for powersave options using keypad and display
Jan 15, 2008 | Canon ImageRUNNER 1670F Copier
old marine
old marine
