Question about Wacom Intuos2 6 x 8 10-Pack (XD68USBAC10PACK)
Delay when activating the cursor - need to click to get it back
My tablet intuos 2 (A5) is having a bit of difficulties when i getting the pen back to the tablet (after a break, even a short one). It takes till 4-5 sec before the cursor gets active again/appears/get recognized... Kinda very annoying... I need to move the pen or even click (touching the tabet) to get it back... However, once active/recognized, it's fine and it works well.
I tried to change the point of the pen and cleaned the tablet surface... didn't help. It's a 5-6 years old tablet, connected via a powered usb hub.
can someone help on this...? I'd prefer a fix than a new intuos 4, even if that'll be a nice upgrade... :-)
Thx!
Federico
SOURCE: cover of the drawing surface come off
The drawing surfce is not glued down and should never be glued down. It is replaceable...
It is basically held on the tablet by an adhesive strip (Double Sided Tape) along it's top edge. I was a little worried too, when after spending some time in Photoshop, it lifted away as if stuck to my wrist.
This is not a fault and it will just lay back in it's recess, no harm done.
NEVER EVER glue it down, or when it comes time to replace it, you will not be able too. If it is peeling up and not laying flat, buy a replacement.
Posted on Aug 23, 2008
SOURCE: Wacom tablet won't recognize pen
Hmm. I've had a similar thing happen with my tablet. Have you tried removing the tablet pen from the list of tools in tablet preferences and then adding it to the list again before checking the 'About' section of the tablet pen set-up and clicking the 'diagnose' button there in? As that worked for me when my tablet pen was not working. The pen was recognized by the tablet after that.
Posted on Sep 03, 2008
SOURCE: My Pen Doesn't Work
I had the same problem. Tried to re-install, install the newest software, but non of that worked. So what I did is knocked 3 times very hard with the other side of the pen on the tablet... and it's working fine now. I guess the tablet just needed a little boost. Hope this will do the trick for you too.
Posted on Sep 11, 2008
  • 5 Answers
SOURCE: cover of the drawing surface came off..
The Wacom website has a note about this in their support section. Don't glue it.
Posted on Sep 28, 2008
SOURCE: Wacom Tablet
http://www.wacom.com/productsupport/select.cfm
Posted on Nov 16, 2008
Where can i get a wacom bamboo tablet?
You can buy them new from places like Amazon or directly from Wacom. Just to confuse you more-- it used to be Bamboo, Intuos, and Cintiq. Now the entry level tablets are the Intuos, the mid-level has become the Intuos Pro, and then the Cintiq.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=wacom+bamboo
https://store.wacom.com/us/intuos-pen-touch/
Feb 25, 2015 | Wacom Bamboo Computers & Internet
Intuos 4 pen clicking while hovering
You may have an issue with the drivers. If you're using the drivers on the CD, try updating to the latest drivers:
http://cdn.wacom.com/U/drivers/IBMPC/pro/WacomTablet_635w3.exe
If you're using the latest drivers and the issue persists, try rolling back your drivers to the previous release:
http://cdn.wacom.com/U/drivers/IBMPC/pro/WacomTablet_634-3.exe
Feb 16, 2013 | Wacom Intuos 4 (PTK1240) Graphic Tablet
Pen and mouse have constant constant cursor jitter Intuos 3 mac
I had a similar problem on my laptop
I plugged the tablet directly into the laptop rather than the USB hub I'd been using until then, The issue disappeared.
Possibly it's a power issue, and going direct cured it?
Jul 29, 2009 | Wacom Intuos3 Graphic Tablet
Unstable cursor
Mainly this is due to your power supply adapter problem.It will be stable when the laptop running in battery i.e without adapter connection
Sep 28, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Intuos pen
Yes, download the new drivers at the Intuos site
Aug 14, 2008 | Wacom Graphire Intuos Pen (GP300ESE)...
Unsteady cursor
I think I have figured it out, I believe it is caused by interference from the computer (probably the hdd). try moving the tablet further away from your tower or laptop.. Mine has to be about 12 inches away to be steady.. I use a Lenovo T61p...
Aug 13, 2008 | Wacom Intuos3 Graphic Tablet
Pen pressure and scale problems
I also use Intuos 3 tablet, did you already try replacing the tip and reconfiguring the pen to the screen? You can find this in the driver software, it synchronizes the pen and tablet.
If you already tried that, does the problem only occur in Photoshop? Also, check your brush preferences, you can go back to your default settings and see. If talking to Wacom fails, you might have a bad pen or tablet.
Jul 07, 2008 | Wacom Intuos3 4x5
Initial Delay of tablet pen
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
Feb 02, 2008 | Wacom Intuos3 Graphic Tablet
Graphire 3 tablet pen troubles
scrap the graphire and get an intuos....i have the same problem....I think the pens are cheap...you might need a new pen. try borrowing someone with an intuos pen.
Sep 12, 2006 | Wacom (EP130E0W01) Digital Pen
Wacom Intuos2 6 x 8 10-Pack (XD68USBAC10PACK) Logo
47 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
