Question about Garden
I have an older craftsman 30" rear engine tractor, last yr it slipped the drive belt, I put it back on, but don't seem to have the power in the lower gears as it did prior to throwing the belt, could the belt be slipping, the engine is running fine, any ideas, also, this tractor was given to me, is there any place to fill fluid for the drive gear, any help would be great, thks Don
    President:
  • 1,033 Answers
The drive belt sounds like it has stretched and slipping causing it not to have the power it once did.
Posted on May 10, 2010
Testimonial: "Thanks, kind of thought that was the problem, will look for a new drive belt, Hopefully I still have the manual, do you know on any sites that would sell parts and drive belts for older craftsman tractors?, thks~!"
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
Jun 08, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a craftsman garden tractor model # 917.273022. when moving the motion lever forward past the "mowing" speed the tractor slows down all most to a stop. moving the lever back it will start...
Depending on the usage of mower it is possible that belt is worn and likely it is stretched just enough to permit slippage. Usually belts will squeal and even have a burning smell. While the engine is often check to see the mechanical actions on the belt and feel for slackness.
Feb 24, 2011 | Craftsman Garden
Our 24 HP Craftsman mower won't go uphill...whats wrong?
Excessive slip under load, such as climbing a hill, is usually a worn belt. It is slipping too much with the extra load of verticle movement. Replacing the main drive belt should get the mower back to original levels of power and therefore back up the hill.
Nov 04, 2010 | Craftsman Professional 24 hp 42" Yard...
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Tractor belt slips so blade doesn't cut
There is an electrical clutch that drives the belts. This clutch may be worn. Some will have adjustments that will allow it to tighten them up and not slip. Now when your tractor is running and you turn on your blades there is power sent to this clutch, it is mounted on the engine shaft and has flexible metal plate that is pulled into a pulley buy an electro magnet this plate is worn or could be full of grass/dirt. You need a good strong light, with the tractor OFF, get under and look at this clutch, look for grass/dirt or if the metal has changed colors meaning it has gotten very hot. If it has gotten very hot it is time for a new clutch... Sorry if this is the case. Good hunting.
May 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lawn mower acts like its slipping going up small hills
check ur drive belt [ runs from the engine upper pulley under frame to the rear trans axle thru a series of pulleys and spring loaded adjusters] the belt has probably worn down or has streched to where it slips under a medium load
Mar 13, 2010 | Craftsman Garden
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
