Question about Keurig B60 Coffee Maker
Makes a terrible grinding, vibrating noise. Won't make a full cup
We have had our Keurig coffee maker about 8 months. About 2 month ago it started making a loud grinding, vibrating noise when it is heating up water for the reservoir and sometimes while brewing for a cup. And now it won't make a large (12 oz) cup. When I try it only makes 8 ounces.
SOURCE: Delivers only small amount of coffee per brewed cup
Same problem happened to me. There is a plastic boot inside the tank that is broken. This seals the top to the tank to the center rod. Keurig will not sell me the $5 part. They would would be glad to sell me a new brewer though!
Posted on Aug 17, 2006
SOURCE: Cuisinart Grind & Brew not using all the water in the reservoir
Same problem . Sent my first machine back (less than 1 year old, you pay shipping and handling both ends) and now after 4 months, same issue. Not sure what to do.
Posted on Feb 17, 2008
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 28 Answers
SOURCE: my Keurig B60, 1 month old is not brewing enough coffee
Check the needle inside the k-cup holder to ensure it isn't clogged. You can completely remove the k-cup holder and rinse it out using your kitchen sprayer to help loosen any debris stuck inside the needle. The needle is what punctures the k-cup and extracts the coffee from within the cup and can become clogged. Make sure when you replace the k-cup holder, that you align the arrows and snap the top or arrow-side in first. If simply rinsing your k-cup holder and needle don't do the trick, try inserting the end of a small paper clip into the needle to push out any remaining debris. This technique is actually recommended by the manufacturer, so it won't void any warranty or damage the needle. After replacing the k-cup holder back into the machine, try brewing a cup of coffee to see if it did the trick.
As a side-note, if you regularly use any "Hot Cocoa" k-cups, you need to make sure and immediately brew a cup of just hot water (no k-cup) to help clean it out and prevent the needles from clogging. The Hot Cocoa k-cups are notorious for clogging the needles up thus causing the problem you described above.
Hope that helps...best of luck!
Posted on Feb 07, 2010
SOURCE: Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Posted on Mar 23, 2010
Ccoffe maker won't brew. Says it is Brewing but nothing. Only about 6 months old was descaled earlier this week.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 27, 2011 | Keurig B70 Coffee Maker
All of a sudden my mom's Keuring B40 won't make a full cup of coffee.
Mine started to do that about a month ago. I would have to brew multiple "cups" just to fill one coffee cup. I ran several cycles of the largest cup, without any K-cups, to clean out the small metal spout. After about 3 hot-water cycles, it worked fine. I do this periodically, as I don't use the Keurig daily, so some of the residue builds up between uses.
Aug 15, 2011 | Keurig Elite B40 Coffee Maker
In the last couple of days our Keurig has been giving us lots of grinds. One entire cup was fllled with them while others have them floating. We use the K-cups from Keurig shipped to us. The coffee...
Hi,The bottom needle is plugged so the coffee is running back out over the top instead of going through the bottom needle...use a paper clip to open it up...
heatman101
Aug 06, 2011 | Keurig Elite B40 Coffee Maker
My platnum keurig is only making about half of what it once did when it was new. I have already descaled it with the vinegar method about two months ago
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 22, 2011 | Keurig Platinum B70 Coffee Maker
Keurig platinum only makes 1/2 cup
call customer service 1-866-901-BREW (2739)
Jun 17, 2010 | Keurig Platinum B70 Coffee Maker
Keurig B60 Coffee Maker Logo
514 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
