Question about Kenmore 73952 Gas Dryer
Gas dryer heats up then cools down may heat up again or may not
Kenmore eco
  • jacknthehat May 11, 2010
    Thank you I will try this
    President:
  • 949 Answers
From the symptoms you describe the problem is most likely with the gas valve coils. Since it is heating at least initially this rules out the safety fuses and thermal devices.
The coils are a pretty basic repair. The first image is a breakdown of the valve showing the coils (13 & 14), with the bottom front panel open you can see the valve. The second image below is the parts and part number.
Let me know if you have questions.
Posted on May 10, 2010
Dryer is running but very little heat if any sometimes
is it gas?if it is and it heats for the first 15 to 30 minutes then you have bad gas coils,they work correctly till they heat up and then they fail,when they cool down they will work again.send model number and i can help you
Jan 22, 2011 | Kenmore Dryers
My dryer is no longer getting hot. it will go through 1 heat cycle then it will not re-ignite. The glow plug heats up to re-ignite the dryer but the gas never re lights. If you un-plug the dryer and...
if it heats for the first 15 to 30 minutes and then no more heat you have bad gas coils,when they are defective they will work until they heat up and then no heat when it cools down they will work again.they are on top of the gas valve,very easy to change
Feb 18, 2010 | Kenmore Dryers
Kenmore dryer is hot at start of cycle but clothes are cold and damp at end
most likely you have bad gas coils?if the dryer runs correctly for the first 15 to 30 minutes and then no heat it's the coils,when they heat up they fail and when they cool down they'll work again for a time then they will die,the coils are on top of the gas valve,change them out one at a time and you should have no problems,remove the 2 screws lift up the metal top and change out the coils
Feb 14, 2010 | Kenmore 73952 Gas Dryer
My dryer will heat only for about 15 mins
you didn't say if it's gas or electric,sounds like bad gas coils,when they're on there way out they work until they heat up and then shut down,after they cool they'll work again
Jan 26, 2010 | Kenmore 63942 Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
Dryer heats for 5 minutes then only blows cool air.
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Aug 17, 2009 | Kenmore 800 7982 Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Kenmore Gas Dryer is 7 years old. It will heat up
Replace the gas valve coils. Common problem after 3-4 years.
Jul 05, 2009 | Kenmore Dryers
Kenmore 73952 Gas Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
