Question about Hoffco TILLER PRO HOE WITH HONDA ENGINE
I am looking for a parts manual for a lil hoe tiller. The lower end of the tiller has seized up and upon disassembly I found some small metal parts that were ruined. can you help
I have a lil hoe tiller and I need a new fuel line that goes into the tank. Where can I find one.
You could try lowes or home depot...however when I work on law equipment such as the hoe tiller or weedwackers, I use tubing for fish tank pumps...you can purchase at supermarket or pet store in like 5-10ft lengths and you can cut it to the size you need. Only cost a few bucks and works like a charm. It is the clear silicone tubing...also just an FYI if your pull started cord ever breaks, you can use parachute cord sold at any sporting good store that replaces the pull starter rope and will never snap again.
Sep 05, 2016 | Garden
Sash cord is stuck - was rotary hoeing the back and all of sudden it stopped and can not pull out to start
It sounds like you seized the motor, the motor was more then likely a 2 stroke and needed to have oil mixed with the gas and maybe the mixture was off and caused it to lean-out and seized the motor. You can pull out the spark plug and put 3 ounces of engine oil in the cylinder and let it sit for a couple of days to see if it will free up, if it does then tip it upside down to drain the oil back out,put plug back in and start it up. If you found this info help full then please click on the thumbs up button. Thanks, Bob
Mar 14, 2011 | Husqvarna Garden
Cant find transmission parts for my hoffco lil hoe. It has a Tecumseh engine
Most Honda Parts Fit http://www.lawnmowerstuff.com/163-Honda_FG100_Parts.html
Jun 01, 2010 | Garden
Service manual for the HP 6110 all in one printer.
A metric allen wrench set (small sizes) is needed to remove the drive mechanism from the document feeder, then the parts can be disassembled. Unfortunately, the drive rollers, made of rubber were damaged by a small metal piece - (staple?) that was fed into the machine. Removal of the metal piece almost restored the drive. It needs to be lightly snded to remove the marks made by the staple. Thanks anyway.
Jan 15, 2010 | HP OfficeJet 6110 All-In-One InkJet...
No spark
No spark can be several things but begin with the easiest first.
  1. Ensure the grounding wire (thin black wire) that connects to the coil is not grounded.
  2. Ensure sure the plug wire end is connected well to the plug wire, some of these clamp the wire interior cord to the metal wire end by wrapping and crimping around the plug wire.
  3. Make sure the ignition generator coil is not scrubbing against the flywheel, there should be .030 air gap between the coil and the flywheel magnets.
  4. If you are mechanically savy, remove the flywheel and inspect the breaker points, replace/adjust as needed.
May 26, 2009 | Mantis 2-Cycle Tiller
Roto Hoe levers
If you have a model 990 rear tine then I could send photos of mine, I have two and they are bulletproof.
This may be all you need: http://www.youtube.com/watch?v=RvuCXCT5Blk
This shows same model in action, let me know if you want photo's.
Mar 25, 2009 | Garden
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Hoffco TILLER PRO HOE WITH HONDA ENGINE Logo
111 people viewed this question
Top Hoffco Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hoffco Garden Expert? Answer questions, earn points and help others
