Question about Sharp Aquos LC-45GD4U 45 in. LCD HDTV
What size screws do I use to mount the TV
What size screws do I use to mount my Sharp Aquos lc45gd4u TV to a wall bracket? Nowhere in the owners manual does it mention the size of the screws for the four holes in the back of the TV. The screws that came with the mounting bracket are too big.
tvtek
  • 1284 Answers
SOURCE: What size bolts for mounting bracket??
I don't know the size but, I can bet it will be a metric bolt.
Posted on Apr 18, 2007
jerryg50
  • 1667 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
SOURCE: Mounting the bracket to the tv?
Hey, I had the same problem and finally found this solution (the four mounting holes are covered by plastic caps as I thought ... just wanted to be sure). Hop this helps:
http://www.avsforum.com/avs-vb/showthread.php?t=1040337
Posted on Dec 27, 2008
  • 92 Answers
SOURCE: I need a longer cord for sharp aquos t.v. for wall mounting
YOU HAVE TO BUY IT FROM SHARP WWW.SHARP .COM
Posted on May 20, 2009
SOURCE: Trouble mounting cantilever wall mount bracket to Sony TV
Finally figured out the correct arrangement or configuration through trial and error (and my wife's puzzle solving ability). It sure wasn't clear in the instructions, and I could not get the needed information from the website of either the manufacturer of wall mount system or TV...a little frustrating, but perseverance paid off. Given the price of the wall mount, I would think they could do a better job.
Posted on Oct 25, 2009
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
What size screws do I need to mount my Polaroid model no. Tlac 02255 to a wall bracket?
Dear Billy,
It is very difficult to determine what size screw for the TV bracket.
  • If you bought a wall bracket, it will definitely have different sizes of screws in it.
  • Follow the installation guide for what Size screw to use on the TV. It varies by manufacturers.
  • Get a Universal Bracket.
Good Luck!
JP
Jul 08, 2015 | Polaroid Televison & Video
Bolt size for wall mount to fit new sharp LC60SQ15U
It will be a metric bolt. They very from model # to model #. Don't get them too long as they could go past the insert and into a PC board!
If you were too Google your model # you may just fine what Metric bolt it would take to mount it. Any good hardware store would have the correct metric bolt or screw for you.
Dec 07, 2014 | Sharp AQUOS 52in. LE820 LED LCD HDTV
Need screws for the back of my TV.Wall mount screws for a sharp LC52D92U
If you have purchased a wall mount kit that will fit a 52" TV there will be screws included that will fit.
Mar 15, 2014 | Sharp Aquos LC52D92U Television
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Sharp Aquos LC-45GD4U 45 in. LCD HDTV Logo
481 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
