Question about Dell 3000cn Laser Printer
Will not stop calibrating
Turn printer on says Diagnosing...then Please Wait... then Calibrating... and printer makes clicking sound.
Inky
  • 691 Answers
SOURCE: printer self calibrating...
This is most likely caused by the toner being low. Change the cart manually with the machine turned off. Open the cart door (not cart d'or - no ice cream here!!) and you will see on the left side there is an interlock which you can push in using a screw driver or similar object. Once pushed in you can rotate the carousel to the relevant point to change the carts. Ensure the tram lines down the sides line up correctly and that you fully insert the cart before turning the carts to the open position. Once changed, power up the machine and I'm sure you should be back in business.
Posted on Aug 14, 2007
Postalsusie
  • 40 Answers
SOURCE: need 2 calibrate my hp 1210 printer
Hi *s*
(bottom left corner windows START)
got to;
start/settings/printers/ and click
right click your printer and select printing preferences
click on the tab that says SERVICES
then click on the services icon button (picture)
you will see three choices;
align,
clean
print a test page.
Aligning is what you want.(calibration is just a different word)
You can also remove the ink cartridges as you usually do and then put them back in, this triggers and automatic printed page and then walks you through scanning and the alignment.*s*
if by chance you still have blurry printing and know your machine should be ok, try cleaning.( same procedure, different last choice- you clean the heads)
You can also check to see if the proper paper is selected. For instance, if you are trying to print heavy greeting card paper it must be set to that or it will not print properly. *s*
If you have thrown up your hands and tried all this, and nothing works. Go through your printer preferences and select SET DEFAULT SETTINGS buttons.
It will knock everything back to the way it left the factory *S*
Thank you and good luck. Please remember to give my answer a rating *S*
Posted on Oct 28, 2008
  • 2976 Answers
SOURCE: calibrating 5100 kodak all in one easy share printer
Go to the printer maintenance program and select "Calibrate printer".
Posted on Jan 31, 2009
rylee_smith
  • 8619 Answers
SOURCE: Waste ink tank almost full i950 printer
Hi!
For resetting the waste ink counter---
  1. Start with the printer OFF
  2. Hold down RESUME and then hold down POWER
  3. release RESUME
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
pressresume button 3 times - light color will change to orange- It will Reset waste ink counter.
Do rate this solution if you found it helpful
Thanks
Rylee
Posted on Feb 07, 2009
tonyludlow
SOURCE: Hi,
There is a chip in each toner cartridge which tells the main machine something about how full it is. It may be that it tells it how full it is, or it may be that it tells it how many pages it has done. It sounds as if the new black cartridge has a duff chip, and is telling the main machine that it is empty. To test this, you can overide the message. 1. press on the menu button;
2. select configure;
3. select maintenance;
4. select non-dell toner;
5. set the value to on.
If that does't work, get back to me.
Tony Ludlow
Posted on Mar 01, 2009
How to reset SC544 for Ricoh MPC 3000 when the keyboard is faulty
Maybe TOUCH panel doesn't work.
Try to calibrate it:
Yellow -->1-->9-->9-->3--> Press Stop(red one) 5 times.
1 - Touch screen adjustment!!! Follow instructions on the screen.
After calibrating exit and try again to enter service mode.
Good luck
Prepare to by new TOUCH Panel
Pifonski
Sep 30, 2015 | Ricoh Aficio Office Equipment & Supplies
Hp laserjet 3600 won't stop calibrating
Probably a DC Controller problem.
Have a tech check it out.
Nov 18, 2011 | HP LaserJet 3600n Printer
Hp laserjet 3600 printer Won't stop calibrating, i try to change toner,reset dafault settings,still calibrating,i canot stop calibration,can u pl sent gud solution. Thanking U shiju
Its a particular problem with this printer, it needs a firmware update.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=1
May 29, 2011 | HP LaserJet 3600n Printer
Dell 3010n printer remain in calibrating mode
Hi
Please try this solution.
Remove the USB cable into the printer and leave the printer
on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK
MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to
the other side of the printer and then move it back to original
position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the
calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Please rate and make a comment if you find this solution very
helpful and might help others as well. Post more comments if
you need more help.
Regards and thank you for using Fixya !
Apr 11, 2011 | Dell 3010cn Laser Printer
When calibrating, it onlt feeds a couple labels
Use the Menu system to calibrate, follow the instructions and it should calibrate with New settings. Calibration by setting it to calibrate on head close or bootup only loads factory settings.
May 03, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
White vertical line on the print
Have you tried calibrating the print head? Turn off the printer and the controller. Turn the printer on. Once the process light turns off, hold down the exec button and press the left arrow. "Please wait" is shown on the screen, and after a while it starts making noises and the screen changes to "calibrating". This is supposed to solve that problem. It didn't for me, but it's a start.
Jan 20, 2009 | Fuji PrintPix NC-1000 Thermal Printer
Magicolor 2200DL
calibrating FW:412050G123D0 I think it says calibrating firmware. what happen before you get this error? did you try to wait for a long time?
Oct 05, 2008 | Minolta magicolor 2200 DeskLaser Printer
Dell 3000cn Laser Printer Logo
687 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
