Question about Lenovo 3000 V100 Notebook
Power on password
How can I remove or disable this power on password
  • Bekiem Mar 28, 2008
    I can't do anything on the machine because if you switch on it just show that you must put on a power on password because system has been tempered
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Go to control panel and click power options in that click advanced there remove tick for password
Posted on Mar 28, 2008
6ya staff
SOURCE:
CLEAR POWER-ON PASSWORD IN XW 6200
Try Below step.
To disable the power-on or setup password features, or clear the power-on or setup passwords, do the following:
  1. Shut down the operating system and then turn off the workstation and any external devices. Disconnect the power cord of the workstation and any external devices from the power outlets.
  2. Disconnect the keyboard, monitor, and any other external devices that are connected to the workstation.
  3. Remove the hood cover.
  4. Locate the header and jumper. The password jumper is green.
  5. Remove the jumper from pins 1 and 2. Place the jumper on either pin 1 or 2, but not both, so it does not get lost.
  6. Replace the hood cover.
  7. Reconnect the external equipment.
  8. Plug in the workstation and turn on the power. Allow the operating system to start. This clears the current passwords and disables the password features.
  9. To establish new passwords, repeat steps 1 through 4, replace the password jumper on pins 1 and 2, then repeat steps 6 through 8. Establish the new passwords in Computer Setup.
May 10, 2014 | HP xw6200 PC Desktop
How do i reset power on password
Hi rmhaynes2004, Luckily, for most laptops, there is Metal-Oxide Semiconductor battery which can charge the power on password to memory on the computer. So, battery also can help us disable power on password to login PC at ease. A. Power off computer; B. Removed the battery and disconnected every cable; C. Short-circuit the two password pads (two small square holes); D. Under the short-circuit condition, power on the computer and wait until the POST (Power On Self Test) ends. After the POST ends, the password prompt does not appear. The power on password reset is finished.
Aug 27, 2011 | Compaq Evo N610C Notebook
Someone gave me a dell optiplex 240 pc they did not have the password i have tried removing the password jumper and also the battery and still it asks me for a pass word help
Make sure you remove the jumper with the power OFF (not connected)
Disabling a Forgotten Password
NOTICE: This process erases both the system and setup passwords.
1 Open the computer cover.
2 Remove the jumper plug from the PSWD jumper to disable the
password feature.
See "Jumper Settings" to locate the password jumper (labeled
"PSWD") on the system board.
3 Close the computer cover.
4 Reconnect your computer and devices to an electrical outlet, and then
turn them on.
This erases the existing password(s).
5 Enter system setup and verify that the password is disabled.
Jul 14, 2011 | Dell XPS 400 PC Desktop
I can not open computer. I need password bios. I forgot the password.
Bios passwords can be reset by draining power completely. remove all power sources, open it up, pull out the CMOS battery, and hold the power button (10 seconds) to drain any residual charge. Turn it on and the password should be disabled
Apr 14, 2011 | Microsoft Dialogue Technology Flybook V5
How to change lock code for compter when fist turned on,.
I'm assuming you mean the bios password. Turn off the computer. Remove the power supply. Remove the battery. Remove the CMOS battery. Hold the power button for 10 sec to drain residual charge. Plug the computer in and boot. The password should be disabled.
Apr 01, 2011 | HEWLETT-PACKARD G62-347NR Laptop
HOW CAN I REMOVE A POWER ON PASSWORD ON NX6110
Do u know the Power on Password? if yes, Go into the bios tapping the f10 key and Go to advance aoptions. There you woul find the options to Enable and Disable Power on passwords.
Regards
Naveen
Oct 10, 2009 | HP Compaq nx6110 Notebook
Bios password reset
dear,
remove power cord from system.
pl set cmos clear jumper on motherboard and power on your cmos password is disable.
May 05, 2009 | Dell Microsoft Windows XP Home Edition
Power On password has been enabled on the notebook
The power on password is configured from the BIOS and removing the BIOS battery will not reset the BIOS and remove the password as it is stored on an EEPROM chip.
This password is to protect unauthorized access to data on the laptop and the hard drive. There are no backdoor passwords available.
Ask the person who set the password, then you will be able to remove it by going into the BIOS setup.
Jan 30, 2009 | Computers & Internet
Power on passward how to removing.
If the password is on power on this would have been setup through the bios setup.
Would need to go into setup and then I believe boot somewher in there will be user password you can disable this and hit F10 to save and exit.Or may be supervisor password which you can try and disable again hitting F10 to save and exit.
If it's the windows password you can log on in safe mode and sign in as administartor then go to user accounts and remove user.
Jan 12, 2009 | Computers & Internet
HP D530
A thing known as BIOS or Basic Input Output System or system BIOS has been configured for security. When after the system starts, you are unable to boot up or go past the password due to a password. Try this:
To delete or disable the Power On password:
Shut down (Power down) the system and disconnect the power cord from the outlet
or the system unit.
Remove the chassis cover.
On the system board, remove the jumper on pins 1 and 2 of header E49 and place
only on pin 2.
Replace the chassis cover and reconnect the power cord.
- OR -
Remove the E49 jumper (green) next to the battery. Make note of whaere jumper was (pin 1-2 or 2-3).
Power on the computer, enter bios (Setup), F10 or F2 (I don't recall if they changed the key)
Disable 'Power On Password'
Switch off PC and replace the jumper.
Jan 10, 2008 | HP Compaq Business d530 Small Form Factor...
Lenovo 3000 V100 Notebook Logo
52 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
