Question about Bionaire BH3930 Oil Filled Radiator Heater
Bionaire Heater #BH3930U - No Heat - Not turning on
When pushing the mode button, unit will not stay on in any heating position (low/high/auto). Red indicator light blinks and I hear a clicking sound like a light switch being turned on and off. When looking into this further, I opened the unit and saw 2 green pc boards. The lower position board is marked "BC6015.PCB" and on this board there are 2 black cubicles marked "coil: 24VDC". The clicking sound comes from one of these coils. Could one of these coils be faulty? If so, where can I purchase the replacement part?
Thank you for your help. Steve Vincze
4 Suggested Answers
SOURCE: Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Posted on Feb 03, 2008
  • 2006 Answers
SOURCE: I have an Bionaire BPH1520
AUTO SAFETY SHUT OFF
The heater has a built in safety device which
will switch off the heater automatically in case
of accidental overheating. It can only resume
operation when the user has reset the unit. For the
BPH1520 (OH)will display in an overheat situation.
To reset the heater:
1. Unplug the heater and wait for 30 minutes
for the heater to cool down.
2. After the 30 minutes, plug the heater in
again and operate normally.
fOR FUTURE REFERENCE HERE IS A COPY OF THE OWNERS MANUAL
http://www.bionaireuk.co.uk/Manuals/MANUALS/BPH1520-UK_43_91313392.PDF
Posted on Jun 07, 2011
SOURCE: polohunt1@aol.com my bionaire bch9221 120
Mine was doing the same thing. Took it apart and found that the white wire which hooked up from the circuit board to the heating element had burnt which broke the connection...hence no heat....replaced burnt wire and resoldered to heating element...put it back together and voila I have heat once more....still doesn't solve why the wire fried though....
Posted on Oct 30, 2011
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
How do I start a 1973 komfort travel trailer water heater?
See if big red knob has a PILOT or LIGHT setting and put it on that setting. Next look at knob on bottom-- it should have a circle cutout on it that needs to align with the pilot push button. The cutout lets the button be pushed in. While holding button in---light the pilot and keep holding the button in for about 3 minutes. If everything is working right with the water heater, after 3 minutes or so you can let go of the button and the pilot should remain on. If it stays on. turn the smaller button to the run or heat position and the big burner should come on. Then set the big heat control knob for the heat setting you want.
May 20, 2015 | Water Water Heaters
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
I have an Bionaire BPH1520 Micathermic Electric heater which will not heat up. I turned it off after use and now will not heat up when switched on. Digital display still lights up? Is there an internal...
Jun 07, 2011 | Bionaire BPH1520 Micathermic Electric Wall...
In the heating mode, blower will not com on in auto but will come on in on mode at tstat
The furnace uses two different speeds. High for a/c (which is the "on" position of the fan switch) and low speed for heat. You could either have low speed of the blower not working or something wrong in the circuit board (if it has one). On the blower motor you may have several plugs that you could change the fan speed and your heat may start working. You will have to access the blower motor to find this out. Red color is low and black is high. Move the Red wire to another speed on the motor and see what happens.
Apr 14, 2011 | Heating & Cooling
How do i light a Reddy Heater rcp 2000 lp gas heater?
hold down the pilot valve knob and turn the arrow to pilot position push down on red button to allow gas thru pilot tube hold down and light keep button held down for 1-2 mins while pilot is on to heat up the thermocoulple then release and turn knob to on position.
Sep 12, 2009 | Reddy Heater RLP100 Portable Forced Air...
Vornado heater doesn't work on high setting but only at low setting
Dust on the inside of the unit can cause the overload switch to shut many vornados down. Blowing the dust out of the unit with compressed air or a blower may help.
Another problem that causes vornados to stop working (light on - no heat no fan) is when one of the bearings starts to go bad in the unit. This causes the fan to be slower and less effective and the unit’s inability to move the heat away from the thermal overload switch again causes it to shut down.
Though you could remove the front and rear bearings and try to get replacements if it's even replaceable ... Once the bearing starts to go bad there is little that can be done ... HOWEVER, here is one solution to get more life out of the unit.
First, use a blower to blow all the dust out of the unit.
Then, because it is typically the front bearing that goes bad first, lay the vornado on it’s back (so the unit would be blowing air up toward the ceiling), this will relieve the front bearing somewhat and rely more on the rear bearing which tends to last longer.
The vornados I’ve had are all thermistor units ... that is, they don’t just turn on and off when the set temp is reached but in fact slow themselves down (both heat and fan) to keep some level of air circulation in the room. This is a good thing by the way.
There are usually two toggle switches .... one is a heat switch - usually Low & High .... the other is the thermistor switch (this sometimes is labeled “fan”) - usually Auto & High.
Once the unit is on its back ... Now, change the settings as follows:
Turn the Heat switch to LOW
Turn the Fan switch to HIGH
Turn the dial (with the temperature in degrees on it) to the lowest setting - which is somewhere around 60’ish.
Now turn the unit on and it should stay working.
Three things that could cause it to turn back off ...
You turn the Fan switch back to Auto.
You turn the Heat switch back to High
You turn the temperature selection dial too high ... though, you can cautiously turn the dial up a few degrees at a time ... the unit will start shutting down again when you set the temp too high ... then just dial it back down ... unplug for a couple minutes, then turn back on.
Oct 22, 2008 | Vornado EH1-0014-01 Compact Heater
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Honeywell Surround HZ2200 / HZ2204 /
A link to an Adobe (Acrobat) Reader format (.pdf) owner's manual for Honeywell® (Mini Tower) SURROUND HEAT™ HEATER FAN Models HZ-2200 (charcoal) and HZ-2204 (white) is here.
Some text from the manual:
SET UP
• The Surround Heat™ Heater is designed to
disperse heat in either a 360° range or in one direction only.
• To select the desired heating mode, slide the Direction Control switch, located
on the top of the heater, to the position of your choice:
– to the right (full circle) for 360° Heating
– to the left (half circle) for forward only heating (One Direction
Heating)
OPERATING INSTRUCTIONS
Select the appropriate heat dispersion mode. (See
Set-Up instructions.)
• With the Power knob in the OFF position, plug the
heater into a polarized 120V outlet.
• Turn the Thermostat control fully clockwise to the
HIGH setting.
• Turn the heater on using the Child Resistant switch
(Power knob). To operate the switch, push down
the two sides of the Power knob while turning it
clockwise to the desired position. The power
light will illuminate. The Child Resistant switch helps
ensure that the heater can not be turned on accidentally.
• When the room reaches a comfortable temperature, slowly turn the Thermostat
control counter-clockwise until the heater goes off. This is the point at which the
Thermostat setting equals the room temperature. At this setting, the Thermostat
will automatically turn the heater on and off to maintain this selected temperature.
• Push down and turn the Power knob to OFF and unplug the heater when you
are finished using it.
Nov 04, 2007 | Honeywell Surround HZ2200 / HZ2204 /...
Bionaire BH3930 Oil Filled Radiator Heater Logo
284 people viewed this question
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
richie46
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
