Question about APC Smart-UPS 1000VA UPS System
Battery does not hold charge
I have an APC X5 1000 back up, I do not know if it is a "smart". size is 14" high x 3-1/2" wide.
Is there a trade in allowance if I puchace another one or are batteries available and easy to install
    Problem Solver:
  • 14 Answers
Normally with 1000VA models, the battery will be user replaceable. You can order a replacement battery pack and replace it.
Posted on May 24, 2010
APC 800va inverter is not charging
Yadava,
If you need pricing on a new or replacement unit I can help. You may also want to look into APC's Trade-Ups program where they give you a discount on new equipment as long as you provide a serial number for your existing: http://buy.apc.com/commerce/storefronts/tradeups/
If you need UPS, Surge, or Power Related help contact:
Inside Service Sales
Daniel Salazar 800.260.2259 daniel@psihq.com
Power & Systems Innovations, Inc.
customerservice@psihq.com
Power & Systems Innovations, Inc. is an Elite Certified Service
Sales Partner for APC/MGE brands manufactured by Schneider Electric
Visit us at www.psihq.com
Apr 18, 2014 | APC Smart-UPS RT 8000VA (0731304239635)...
APC Smart-UPS RT 10000VA 230V battery charging voltage high
voltage is ac,,,,better get a new one before u fry your self
Nov 09, 2013 | Computers & Internet
APC PRO1300 F04 CLAMP SHORT ERROR CODE WHAT DOES IT MEAN AND HOW CAN I FIX?
F04 indicates that "Clamp Short" it could be anything, but the word "clamp" reminds me of a varistor / MOV, which is the component that clamps short when there is a voltage surge condition and comes back to its normal state, an open circuit, when the voltage surge is gone. Sometimes it clamps short for good when it is hit by a large surge or just by absorbing and shunting to ground many small surges.
You can brain dead the UPS to check if that resolves the issue. This brain dead test helps to reset the internal circuit of UPS.
1. Disconnect any attached load.
2. Turn off the UPS
3. Unplug the UPS from the wall socket.
4. Disconnect the UPS internal battery.
5. Push and hold the "On" button on the UPS for 5 seconds.
6. Reconnect internal battery.
7. Plug UPS in to known good power source.
8. Turn the UPS ON.
If the same issue remains even after brain dead then you have to replace the UPS. This UPS comes with 3 years of warranty, if it is under warranty you can contact APC support at 800 555 2725
If the UPS is out of warranty then you can participate in APC Trade-UPS program. APC has Trade-UPS program where in you can trade your old unit and get a new unit with great discount. You will also get a return shipping label to ship the trade-in unit to us. You can refer to the below mentioned URL.
http://www.apc.com/shop/tradeups/us/en/tradeups/overview.jsp?agent=a190004&countryCode=us&language=en&userType=endUser&user=21867960&_requestid=105040&_requestid=105040
Mar 02, 2013 | APC Power Saving BackUPS Pro 1300
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My ups does not give enough back up and the others are not powering
It is usually a battery problem.It is not charging anymore.The battery is the power source for your UPS once the AC source is cut off.Open the unit and there you could locate the battery enclosed inside the UPS box unit.Replace it with the same type and size of battery, observe polarity where the red is (+) positive and black is negative (-).Depending on what the manufacturer used for the color coding but still see where the Positive and Negative wires are connected to.But before you open the unit remember to unplug the unit from the power outlet.
Nov 06, 2010 | APC Smart-UPS 1000VA UPS System
All battery charge lights flash simultaneously.
THIS seems the be the answer to your question. Hope this helps
Apr 29, 2010 | APC Smart-UPS 1000VA UPS System
The ups 5kva apc ups does not back up
Sounds like your battery is on the way out. Try a new battery, leave it charge for 15hrs before using. Should be ok after this.
Apr 21, 2010 | APC Smart-UPS 1000VA UPS System
We can charging for 100AH battery for in 650 APC UPS. its possible or not
Yes you can change the battery. All you need to do is ensure that the replacement battery has the right physical size to fit in the cabinet and meets the required spec. Simply having a larger AH rating means that it will last longer under load when it is required and will take longer to charge after it has been used.
Sep 29, 2009 | APC Back UPS 650 (APWBK650MC) UPS System
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
APC Smart-UPS 1000VA UPS System calibation problem
If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA UPS System Logo
337 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
