Question about Novelty Watches
Movt v-490 bought the watch at walmart. counts seconds by 20, then to 40, then changes the minute. that's fine, but it counts so fast that it thinks 30 sec is 1 minute.
SOURCE: Second Hand
smash it with a hammer
Posted on Feb 10, 2008
SOURCE: seconds hand moving by 4 sec at a time?
yes, that's the low battery signal
Posted on Aug 23, 2008
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Posted on Feb 05, 2009
  • 65 Answers
SOURCE: Need a replacement two tone metal watch strap for
Enquire with either a Pulsar dealer or a watchmaker they may be able to get it for you. If you have a trade supplier near you they may also be able to order one if available.
Posted on Jul 25, 2009
  • 59 Answers
SOURCE: eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Posted on Aug 06, 2009
My watch stopped working and I think it has something to do with the battery. How do I replace it?
for you , the quickest and easiest way would be to take it to a jeweller and have it replaced
time taken around 5 minutes
Oct 17, 2017 | The Watches
How can I get back off a Disney watch with Japan Movt?
i use a razor and a hammer.or send to me watchrepairbattery.com
Mar 31, 2012 | Disney Watches
Watch Manual for Sergio Valente model# F-IAGAG
These are operating instructions for an SV F-IAGAG (Sergio Valente) watch.
There are four buttons on the watch.
A: upper left
B: lower left
C: upper right
D: lower right
Pressing A turns on the watch face backlight.
Pressing B changes the mode.
From the normal time display mode, one press of B enters the stopwatch mode. In this mode, pressing C will start the stopwatch time count. Pressing C again will stop the count. Each additional press of C will start/stop the count. While the count is proceeding, pressing D will freeze the display of stopwatch time, yet the count will continue. Pressing D again will cause the display to begin updating with the running count. Each press of D will freeze/unfreeze the display update. When the count is stopped (with a press of C), pressing D will reset the count to zero. From this mode, press B again to return to time display mode.
From the normal time display mode, two presses of B enters the alarm time set mode. In this mode, either the hour or minute portion of the time display will be flashing. That which is flashing can be changed by pressing C. Pressing D will switch to the other portion (hours or minutes). Any time the alarm mode is entered and a change is made, the alarm is set to "on". This is indicated by a check mark in the circle display next to the "9" on the watch face. The alarm can be toggled "on" and "off" from the normal time display mode by holding down button D and pressing button C. Return to the normal time display mode by pressing button B while in the alarm time set mode.
From the normal time display mode, three presses of B enters the time set mode. Upon first entering this mode, the seconds display in the circle near the watch face "3" will be flashing. Pressing button C will reset the seconds to zero. Each press of the D button will advance to a different value field for adjustment. The field of adjustment will be flashing. The sequence of fields is (seconds - minutes - hours - date day - date month - date day). Pressing C will change the value. When adjusting the hours, both 24hr format, and 12hr AM/PM format is available. Each press of button C will advance the hour value. The sequence of 24hr format will be indicated with an "H" in the "seconds" circle (near the watch face "3"). After hour value 24 of the 24hr format, the next hour is a "12" value, with an "A" in the seconds circle. Twelve presses of button C will step through the AM hour values and present an "12" value with a "P" in the seconds circle. Twelve more presses advances through the PM hour values and returns to the 24hr format. Pressing button B will return to time display mode.
Pressing button C while holding down button D will toggle the alarm "on/off" state. The "on" state is indicated with a check mark in the display circle next to the "9" on the watch face.
Jan 08, 2012 | Watches
I bought a casio watch (model AMW-320R, I think that is the model number) with both a tradiotnal hour, minute, second hand and digital readout. The digital readout is fine but the second hand on the...
Normally this is the battery... Try the battery before considering to send the watch to Casio for service. Or, if you send it they will fix it and send it back. They are not very expensive for their service.
Jan 26, 2018 | Casio Watches
Bought a generic clip watch from walmart with no manufacture's name on it. The back says MSP74582W batery CR1616 and then A126. Looking to find instructions on how to set alarm, date, and figure out...
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst
S2 - at 2 - St/Stp
S3 - at 8 - Mode
Light - at 10
Watch Control
Normal Display: Hour, Minute, Second
Push S1: Alarm time in Hours and Minutes
Push S2: Month, Date
S3: Change function
Alarm and Chime
In Normal Time Hold S1 and the alarm time will be displayed.
Press S2 once and Hourly chime will be on.
Press S2 twice and Alarm will be on.
Press S2 three times and Chime will be off.
Press S2 four times and Alarm will be off.
Press S1 and display will change to normal time immediately.
Setting Alarm Time
In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
To silence the alarm, press S1.
May 15, 2011 | Watches
I bought a cheap plastic bezel 1004 watch at walmart but there were no directions in the box and i can't get it to set. does anyone know how to set these?
to set the time you press mode ( the button in the bottom left) twice. to set the alarm you pressmode three times and to change the unit of time (hours, minutes, seconds) press the bottom right button (reset)
Nov 22, 2010 | Watches
How much is a elgin base metal bezel japan movt is worth?
mcdevito75 here, Elgin a great name in watches, usually the back of the watch is base metal while the bezel or fron of the watch is plated, almost any jeweler can give an approx. value to your watch, of couse it"s age and condition count for alot.
Jun 14, 2010 | Elgin 0518709FA
I bought a ARMANI CHRONO WATCH - AR0294
Big hand is for chronometer function, not for counting seconds. The small seconds hand is for continuous seconds counting and should tick all the time.
Mar 24, 2010 | Giorgio Armani Emporio Armani AR0527 Watch...
Ozon japan movt quartz watch manual
I have a Japan MOVT watch given to me by my daughter. The battery died and i have not worn it in some time. I got the battery replaced now i can't set the digital time or the date, etc. What is the procedure?
Dec 02, 2009 | Watches
I have Minicci watch and i wonder if it is real? It said it is stainless steel back made in china quartz japan movt 31290...
It is real. Manufacture in China is cheap and many of brand names are manufactured there.
Japanese movt is right and real as well as these are mass produced for many different brand names.
Nov 27, 2008 | Kenneth Cole RK5034 REACTION
Watches Logo
159 people viewed this question
Top Novelty Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Novelty Watch Expert? Answer questions, earn points and help others
