Question about Apple iPhone Smartphone
My iphone doesn't work - Apple iPhone Smartphone
Phone frozen up wont do anything not even coming on
You could try a reset.
Hold both the Home and Power buttons until the iphone begins to start.
It should take about 10 seconds.
It this does not work, your battery may be low.
Connect charger and try reset again.
Additional help from Apple support page.
If your iPhone iPad or iPod touch doesn respond or doesn turn on
Feb 21, 2015 | Apple iPhone Cell Phones
My Smart satarter doesn't work because I upgraded the iPhone 5s to iPhone 6 plus. I redoenloaded the viper app but it doesn't work?
There can be problems when iOS is upgraded. Get the latest version with the latest bug fixes. Watch the Viper app for version changes and download it when it gets updated. Check the Viper support web site:
http://www.viper.com/Support/
Jan 06, 2015 | Remote Start System
Hi, when i have my iphone 4s on the charger, which i do every night, the alarm doesn't work in the morning, if i take it off the charger it works?
It sounds like your phone is getting stuck in "Dock Mode" where it disables the sound of your phone while docked. I would make sure you have the latest iOS (update your phone through iTunes. And if that doesn't work, I would search the internet for "iphone stuck in dock mode" for some more in depth reasons/solutions to it.
Jul 05, 2012 | iHandySoft Alarm Clock Pro
My iPhone YouTube doesn't work
Try restoring the firmware.
Is your iphone jailbroken? If it is, there might be a tweak you recently installed that could be the problem. Undo the tweak, reboot, and check youtube.
May 17, 2012 | Apple iPhone Apps
Iphone 3gs screen problem
If the problem is consistent in other windows besides strictly the keyboard it is possible that the capacitive touch panel is defective or has been damaged.
Dec 12, 2011 | Apple iPhone 3G
WHEN I TRY TO SEE RECENT CALL HISTORY THE I PHONE 3 GS REVERTS TO THE HOME SCREEN. IS THERE ANY WAY OF RESOLVING THIS?
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Jun 30, 2011 | Apple iPhone 3G
The home button on my iPhone 3Gs doesn't work AT ALL. Also when I try to make a phone call no one is able to hear me.
Hi
The probably came when your handset dropped, The best option go to apple service center and repair it. because the connection is home button doesn't make the transmit the data to phone.
Jun 22, 2011 | Apple iPhone 3G Black Smartphone
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
The touch screen on mym phone wont work its jst not working all together it just stoped
hi friend,
  • Issue – Bottom half of iPhone touch screen does not work.
    Solution - Standard troubleshooting steps in order are power the iPhone off and on, Reset, Restore from backup, Restore as a new iPhone or not from backup and if no change after any or all, call Apple Care – (800) 694-7466 or make an appointment at an Apple Store to have this checked if there is one nearby.
  • Issue - iPhone “touch screen” dead.
    Solution - Connect your phone to iTunes and do a full restore, it will replace all information on your phone prior to your last syn. If it doesn’t help call Apple Care – (800) 694-7466.
  • Issue - The top half of my iPhone screen is not working at all
    Solution - If restore doesn’t work – you could schedule online an appointment with a genius at an Apple store
    http://www.apple.com/retail/
  • Issue – My screen cracked. How much would it cost to get it replaced?
    Solution - Terrible situation but Apple doesn’t warranty the glass. This would be a minimum of $250 to get fixed out of your pocket.
Hope one of the solution helps…
thank u for using fixya
please rate me..............
regards
sivaranjini
Sep 12, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Apple iPhone Smartphone Logo
200 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
