This problem should be removed because:
Problem with Microsoft Office Access 2003 (077-02871) for PC
We have an exsisting Access 2003 database. My coworker was given a new computor and now when he trys to use the database he gets the following prompt: "The expression you entered has a function
name that mircosoft office access can't find." What do I need to do in order to get this problem solved.
Solutions (1)
You are probably missing a private library on the new computer, or have an incomplete installation of Access. Then simple functions like Date() or Trim() don't work, or user defined functions in a private library cannot be found. Your access project probably uses a special library that needs to be copied to the new computer, and it needs to be properly referenced by the Access project.
To see what libraries an Access project has referenced, open any code window (e.g. press Ctrl+G), and choose References from the Tools menu.
If a library is marked MISSING, click the Browse button, and locate the correct file for the library. The table below lists the files for the crucial libraries of your version of Access.
If the library is not even shown, you may need to re-register it. Click the Windows Start button, and choose Run. Enter regsvr32 followed by the full path of the library file. Include quotes if the file name contains spaces, e.g.:
regsvr32 "c:program filescommon filesmicrosoft shareddaodao360.dll"
Occasionally, the problem is not solved until you unregister the library and re-register it. Uncheck the missing library in Access. Close Access. Issue this command, and then the one above to re-register it:
regsvr32 -u "c:program filescommon filesmicrosoft shareddaodao360.dll"
Re-register it (as above). Open Access, and select the library reference again.
mircosoft office 2000 product code
hi , i have a burned copy of mircosoft office 2000 but that person has recently passsed away we can't find the product code . can you...
do you know how to
do you know how to clear the data base in Restaurant Pro Express
I installed oracle 10g express edition.now I dono
I installed oracle 10g express edition.now I dono how to remove it. please let me kno how to uninstall it.I even stopped the oracle services...
want a free download of
want a free download of micro soft word
Add Your Solution
Microsoft Access Report Creation
Creating a report in columnar form (details / titles down the left hand side). I want multiple columns to appear on the...
how to use validation rule
how to use validation rule in microsoft access?
what is the maximum number
what is the maximum number of records that Access 2003 can process in a query? I am finding that when I bring a large...
i wants download ms access
i wants download ms access 2003
See all Microsoft Office Access 2003 (077-02871) for PC Problems
Fix-O-Meter
32
32 people viewed this problem
- 0 people are following this problem. Be the first!
Top Microsoft Business and Productivity Software Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
