Question about DISH Network 311 DTV Receiver
My receiver turns off and on and trys to run a system update but when it is complete it turns off and you can here the fan blowing and then it starts the update again. It will only show the channel you were on for a second maybe.
    Problem Solver:
  • 17 Answers
Hello tsaucier, my name is MichaelHurst with DISH Network. Is your receiver plugged directly to the wall outletor to a surge protector/power strip? Unplug the DISH receiver for 10 secondsand plug back in. (It may take up to 5 minutes for the reset process to becompleted). Ifthereceiver is currently plugged into a surge protector, bypass the surgeprotector and plug the receiver directly into a wall outlet. If you are stillhaving issues try another outlet. If this doesn't remedy the issue then thereceiver will have to be replaced.
Posted on Feb 01, 2011
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
When i turn on my hp all in one computer,it's telling me cpu fan can not be detected
Hello user...you are receiving this message at start-up because, in your bios system settings, "run fast diagnostic test" is enable...CPU fan is like a computer fan but attached with the cpu to cooled the cpu so that the cpu will function properly so as the computer...perhaps there is a problem with the fan, so its not running when the computer starts. This may harm your CPU, as a result may blow the circuits in the motherboard and eventually your computer will crash....for a technical advice, you may want to visit the nearest PC repair shop and change the cpu fan..
Jun 23, 2014 | HP Mini 1000 Netbook
Battery fuse keeps blowing
that is the problem . who ever hooked up the fan it is cut into something. I bet if you umhook the fan you will stop blowing fuses
Nov 23, 2012 | 1997 Infiniti.5 Q45
No ac nd my fan stop working completely
Fuses blow because of higher than normal amperage in the circuit. Not sure what circuit the blown fuse is for but if it is for the fan the fan may be shorted therefore blowing the fuse. If you put fuse in while the ac was still on try shutting off the ac then putting the fuse in. See if it blows then if it doesn't then turn the ac on and if it blows you have at the very least isolated the system at fault.
Jun 16, 2012 | 2001 Chevrolet Impala
Fan blows high speed and computer wont start
How long havew you had the present motherboard in your computer? if over 3 years (and used on a dayly basies more then likely, your motherboard is in need of replacment because the capasitor/s are leaking (not giving the proper voltage to start and hold your computer at proper levels
Jan 14, 2010 | Dell Optiplex GX280 (99301) Motherboard
Fan stops turning after about 30 seconds
this sounds like one of your capacitors has failed
using an insulated screwdriver and, power not applied remove the spade connectors from one of the capacitors then short the capacitor to ground to discharge it replace the spade connectors apply power and, turn it on if the problem changes replace the capacitor (a bad capacitor usually is "bulged")
there are usually two capacitors a run and, a start
May 29, 2009 | Dometic Rooftop RV Air Conditioner
Bios Up date problem
I don't do many BIOS updates (mostly because they can be fatal to your system if they go wrong) but my general understanding is that if the update does not finish then you are out of luck. Your best bet will probably be to replace the motherboard completely.
Hopefully someone on here has a better idea though...
Best of luck :)
Dec 11, 2008 | Gateway 835GM (835GH) PC Desktop
My heat pump is fan is running at half speed and continues to blow fuses
Either the dual run capacitor has failed and is not providing the help the motors need or the compressor has shorted out internally causing the fan to run when the a/c is off and then blowing the fuse when it trys to turn on.
Jul 01, 2008 | Heating & Cooling
AC keeps blowing fuses
Fuses are a protection device and I guess that this is for the condenser section and compressor. If they blow right now when it is turned on would indicate that there is a short in the wiring or motor or compressor. If it trys to start and the outside fan starts and the compressor just humms and blows fuse, you have a locked compressor. Might check run capacitor or install a hard start kit and see if it will brake it loose, if not bad compressor
May 31, 2008 | Ruud UBHC Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
DISH Network 311 DTV Receiver Logo
147 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
