Question about Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac
I have an 850v laserline fitted to my m/cycle and it has totaly imobilised the engine & no longer responds to the remote buttons the unit is 12 yrs old. can anyone advise ? !!
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
Windows 7 driver Adrenaline 850V PCI Video Card
Does anyone know where i can get a Windows 7 driver for the Adrenaline 850V PCI Video Card pls???
Sep 11, 2012 | Kofax EH-0850-2000 Adrenaline 850V PCI...
How to syncronize 2 keyless remotes for 2000 gmc sierra
Here is the way to do it.
1. Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down
until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by
door locks locking and unlocking automatically. (If locks do not cycle after you let go,
not before you let go of the unlock button, then the vehicle has not entered programming
mode and you must start procedure over. Remove key from ignition, open drivers door
and return to step 1 ). If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and
unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
May 25, 2012 | 2000 GMC Sierra
Select & skip forward buttons no longer work on the #2 UHF remote
THis solution depends on your ability to do it yourself.
If you are brave enough you can disassemble your remote and dust the black blisterpads with graphite powder being careful to blow off any residue before reattaching. This will add some life to that old remote, but eventually all things must be replaced. Graphite powder can usually be found at most office supply houses and some Schools. It is usually used to lubricate slide rules.
Mar 07, 2010 | Televison & Video
I need to mprogram a new remote that I just
. Close all doors 2. Insert key into ignition
13. Test remote(s).
Jun 12, 2009 | 2001 Chevrolet Blazer
Aircon no longer responds to remote handset
Open the front again and make sure that the operation selector is set to remote control. If it is, then I suspect that your remote sensor reciever on the aircon unit is bad. It is very simple to replace.
May 06, 2009 | Heating & Cooling
Synching wii fit causes wii console to no longer power up
1, Turn off and unplug your wii console for a few minutes
2,Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
then try syncing your wii fit bored
Dec 28, 2008 | Nintendo Wii Console
Trouble with Air Con Unit
Try to run the unit by pressing the manual button in the indoor, if it works then try the remote control if it will respond. But if not try to unplug the power supply or "off" the circuit breaker and "on" again and try the remote control if it works then the remote is ok if not may be the receiver is defective.
Nov 09, 2007 | Heating & Cooling
Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac Logo
111 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
baire
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
