Question about Echo Garden
How to rewind echo SRM-200 recoil starter for Trimmer
  • 7 Answers
SOURCE: Echo SRM 1501 trimmer has minimal fire. Feels very
If this is a solid state ignition ( black box mounted right next to the fly wheel)check for rust on fly wheel and coil/ignition.Sand with light grit sand paper if nessesary. Make sure to reistall with the same gap between the two parts.note the gap at this point could also be wrong.Also check to see if the clip inside the boot where the spark plug conects is not bent and that it is conecting properly. If this is a points ignition system then its basicaly the same steps.Clean contact pionts check plug boot for good contact. Or could be bad coil.Be sure you are using a plug with the propor heat range.
Posted on Jun 08, 2009
SOURCE: How can I remove Echo 230 SRM trimmer head?
Remove the top off the string housing and remove the nut in the center.
Replace the top, as if you have finished loading string, Lock it in place as you normally do and the turn the entire housing pulling up at the same time. Spring and the white mechanism will pop out and then all you have to do is lift the string housing base off the trimmer head. Note it will take you a few tries but once it comes off you will see how easy it is to remove. I was amazed. Got my info from a sales person at Home Depot.
Posted on Aug 01, 2009
  • 10 Answers
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
  • 1126 Answers
SOURCE: i need an instruction manual for echo srm 225 weed
http://www.echo-usa.com/documentation.asp?Model=SRM-225&lang=E
Hope this link helps.
Posted on Sep 08, 2009
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
On my echo weed trimmer the rope broke on the starter. i took it off and the spring came out. how do you reconnect all the workings?
Recoil starters can be very dangerous when coming Apart!!, And During Reassembly!! Please do not attempt unless you are a qualified and certified Echo technician!
The spring of the recoil is what pulls your rope back in, It is of high energy and can harm you during Assembly, if you fail on any one detail. The most common injury is to the eyes! Use proper eye safety when performing repairs on recoil starters!
Re assembly process as follows,,
For parts info, go to http://www.powermowersales.com
Jun 11, 2011 | Garden
How do you rewind the starter rope spring on an Echo PB-200 Blower.
assuming the spring has not broken behind the pulley causeing this problem you should be able to just re tension the spring, hook the starter rope into the slot in the side of the pulley, this will allow you to wind the pulley ( in the direction that the engine rotates ) up, when you have turned it enough times that the spring is coil bound ( be careful as the spring will be under a great deal of tension ) release the pulley then one whole turn, now unhook the starter rope and allow the spring to recoil ( dont just let it fly back ) and wind the rope in.
Feb 04, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
How to wind starter rope recoil spring on echo srm-200 grass trim
I would take it to the dealer. I know that might be money you don't want to spend but better than having a broken saw. You could try their FAQ section, it's pretty thorough: http://www.echo-usa.com/faqs/
May 10, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Jun 07, 2009 | Echo Garden
Garden Logo
204 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
