Question about LG Prada KE850 Cellular Phone
Lg ke850 memory card wont activate
  • Anonymous Nov 06, 2008
    mine wont either
  • 23 Answers
Just to let you know, Sd memory cards that are larger than 4gb are in a different format, so the LG KE850 only supports memory cards up to 2gb.
Is it 2gb or smaller?
Posted on May 23, 2009
SOURCE:
I put a password in 1gb sd memory card in nokia2730 but i forgot my password thats why i cannot active my memory card
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
Hope I make it clear and does makes sense
Oct 12, 2012 | Nokia 2730 Classic
Its internal memory is 6 mb it is said that it suppots memory card upto 2 gb but it isnt detecting the card.should i activate it where and how
there's no activating stuff and all...
  • make sure that your memory card is working.(put it in your friends phone and check it)
  • then 2nd your memory card slot fine and working.
these are the only reasons which can be behind it.
  1. faulty memory card.
  2. faulty memory card slot.
have a great day!!
Jun 13, 2011 | Nokia 5200 Cellular Phone
It wont let me take any pictures even though i bought a new card it still shows app.5or 6 pics but wont take any more It just keeps reading internal memory is full
This kind of problem is mostly associated with cards that have been used previously or that have had some sort of formatting before.
The problem you are encountering is this, the card is full with system files that are mostly hidden. Majority of these files are usually log files that keep a record of all the activities the card might have undergone since it began usage.
The only thing you can do to solve this problem is to format the card suing your computer. Formatting the card would help you get rid of previously existing log files and would free up space for new pictures to be stored.
If this doesn't solve your problem, then you may be having a faulty card.
On the issue of having full internal memory, if you have the option to format your internal memory, go ahead.
If you don't change the default save location to the memory card if one is available.
Let me know if you need any assistance with formatting your card.
Jan 28, 2011 | Cameras
When i turn my camera on it says memory card is protected and i wont take any pictures, what should i do?
The memory card is most likely an SD type and the lock swich was activated I'm including a diagram to show you the correct orientation of this switch, it must be in the open or unlocked position to function. When you have the memory card unlocked Please format the card so the camera can function properly with it. Formatting the card will insure correct programming between the card and the camera. Format the card after downloading pictures to the camera. it both cleans and restores programing so the card and camera are compatible once again.
Lock is down open is up towards the top and closest to the gold contacts
Jan 06, 2011 | Cameras
Kodak 10.3 camera lance wont fully extend when
Here are the steps:
1. Make sure you will install a new or fully charged
battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from
your camera, then wipe the battery contacts with a soft,
clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Does anyone know how to activate memory card on Lg K360 !?
For my LG Banter (also a side-slide) I do this: Menu / Setting / Memory / then choose Card Memory, instead of Phone Memory.
Jul 28, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Digital camera
personally i never connect the cam to pc using the usb cable, i take the memory card out and put it in an sd card usb adapter, you say the images are protected, this tells me that you have the lock switch activated on the sd card...hope this helps :)
Jul 11, 2009 | Samsung L100 Digital Camera
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
How do i activate my memory card, its a nokia phone
Theres nothing to activate in a memory card..Just put the memory card properly and if you switch on the mobile then your memory card will abe automatically detectable and ready to use!!..
Aug 01, 2008 | Nokia Cell Phones
Memory card
There is no need to activate it if it is already formatted If not so, format it by selecting memory card>Options>Format memory card.
Feb 09, 2008 | Cell Phones
LG Prada KE850 Cellular Phone Logo
241 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
