Question about Motorola Mobility RAZR V3
Hi my razor 3 phone has lost the charactors on the screen i just have a lit screen phone still works
  • coosajeep May 10, 2010
    hello i accept that probablymonitor is shot how do i replace is show me some picts and explain
    thanks lanny
  • 2,335 Answers
If your phone still works fine, (receive calls etc) but the screen is black, then it is very possible that the flex cable under the front cover has become loose. There is a fix that is doable yourself if you are handy, otherwise you will need to take it for servicing.
You can try just pressing on the lower left hand corner of the screen while powering the phone on and that might help. Otherwise follow the steps in this Motorola Disassembly Guide to expose the flex cable connections for the screen.
Corrupt firmware or a 'bad flash' can produce the same white screen, but no functionality, so I recommend you review that tutorial.
I hope that helps.
Posted on May 11, 2010
    Genius:
  • 1,040 Answers
Dear Coosajeep,
Screen is for just viewing purpose. It works exactly as Monitor of the computer. your screen has stop functioning. You have to replace your screen......
Since You said that only character has lost( i.e. if you can see wallpaper) then reset you cell to factory defaults..... if problem persist then update or reinstall software.........
Posted on May 10, 2010
I have a Motorola razor phone. The phone was on and the screen was black but the buttons were still lit up blue. I turned off the phone and now the buttons are still lit up blue even when the phone is...
Hi, it is the flex of the phone that connects the screen board to the main board that make the screen display is faulty and it needs to be replaced with another flex.
After changing the flex, it will work perfectly again.
But sometimes you might still change the flex and it will still b e showing blue. In that case you will need to change the screen of the phone.
Take care.
May 21, 2010 | Cell Phones
My razor wont turn on
try borowing a batterie from a friend moto is notorious for this problem
Aug 04, 2009 | Motorola Mobility RAZR V3
Frozen ''hellomoto'' screen on Razor V3c when turning on phone
You have a couple of options:
Take it to a motorola repairer or try to update the firmware on your phone. As you cant get it to go past the Hellomoto screen a hard reset would not possible.
Apr 05, 2009 | Motorola Mobility RAZR V3
Screen went black
If when you try powering up the phones and the keypad just lits up then it is the flexcable that needs to be replaced.
or the LCD
Oct 03, 2008 | Motorola Mobility RAZR V3
External display will not shut off
from settings find the option of screen display, find the choice for screen back light, and change the time to 3 seconds or 5. It is in there just browse thru your setting for screen dislay.
Artgirl
Jul 18, 2008 | Motorola Mobility RAZR V3
SCREEN
the hinge is the middle of the phone where the top and bottom of the phone meet think of it this way if u close ur razor the top of the phone is the hinge its the things where it has two shiney cirlces on each sides hope that advice helps thanx.
May 19, 2008 | Motorola Mobility RAZR V3
Norstar M7208 display screen garbled
Increase the contrast of display of ur phone it might fix the problem
May 13, 2008 | NorStar M7208 Corded Phone
My cell phone wont display anything
I had the same problem with an old razor. I ended up having to discard the phone and got a v557. But these were the steps I took: 1. Took out the battery for about 5 min. I called tech support and they said that most problems are due to software errors and can be fixed by taking out the battery then reinserting it. 2. I reinserted the battery and booted it up. The keyboard lit up and the welcome screen played. After that, it shut off. 3. I charged the battery completely and tried to reboot. Same thing happened. If none of these work, it's probably the battery's fault or the phone's fault. Either way, you should get a new phone or contact a professional fixman. Hope this helps.
Jul 27, 2007 | Motorola Mobility V551
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Jul 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
