Question about Sony Handycam DCR-TRV350 Digital Camcorder
Recording how to record from camera to vcr
  • 42 Answers
You connect cable from camera to an adaptor cable with phono plugs in and scart out. Plug the scart connector to the vcr scart input and press record on vcr and camera. Remember to choose the scart input on your vcr.
Hope this was helpful, i can might make a drawing to explain if you need it.
/michael
do it you self blog
Posted on Mar 28, 2008
SOURCE:
Lorex security camera
Coax from camera needs to feed vcr, at line in, line out from vcr goes to input of tv ie av1 av2 video in what have you. go that far and see if it makes sense.Then you can set vcr to record continuous and watch it at same time on tv or monitor.
May 14, 2017 | Lorex Home Security
How do i record with my vcr im trying to record with my surviellance camera but its not recording
The surviellance camera must be connected to the video box so that you have the composite video output signal to be given back to the VCR video Input. Only with this rrecogniosable siganl will the VCR record your visuals.
Sep 16, 2010 | Memorex MVR2031 VHS VCR
How can i record in vcr
On the power switch. Does it say camera/ player or Camera vtr. If it says player you can not record in vcr as you put it. In the earily days when camcorders were $800 and over ,they all Recorded from line in in the vtr mode. Not any more . See you you can switch to line in mode in the vtr postion however. Larry's Electronics 916-362-8708
Apr 23, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a security camera outside that runs to tv with rca cables. i want to record to a vcr which is connected to tv by coax. i cant get it to record the camera picture. can u help?
The coax connection is one-way RF only from the VCR to the TV. It cannot be used to record from TV to VCR.
Run the RCA cables to the Line or Aux input on the VCR first. Watch on the TV through the coax connection to the TV. You can watch even when not recording the camera signal on the VCR by setting the output of the VCR to Line instead of a channel.
Another option would be to connect a component (RCA) output from the TV (if there is one) to the VCR Line or Aux input.
Dec 16, 2009 | Office Equipment & Supplies
I have a Zenith DVD/VCR and I am recording a tape
unless the security camera has a setting for recording the date stamp you probably can't. The camera probably has a setup tab to enable embedding the date stamp on the video.
Nov 14, 2009 | Zenith XBS448 System
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
I need to connect my security camera to my vcr
Hi You need to connect the camera via a scart lead (or yellow phono plug on some VCR's then set video to record on AUX channel.
Mar 25, 2009 | Televison & Video
Connections, security camara/vcr/tv
A VCR uses a "RF" signal, where a TV uses a broadcast signal. The standard TV will not record from a security VCR. However, if the TV has a yellow "video in" jack on the back, this will work to record the VCR. You might need to buy a BNC to RCA adaptor at radio shack. Let me know if this does not work.
[email protected]
Nov 25, 2008 | Home Security
Convert miniDV to VHS
You use the mini to triple RCA cable with the camera and go into the menu and make sure you are on A/v out instead of headphones. You just hit play on the camera and record on the VCR and Whala, it's done.
Videoteacher
Nov 26, 2007 | Canon ZR70MC Mini DV Digital Camcorder
How to record from a VCR onto a canon mv530i
OK get a set of cord that can be used, on the back of most VCR's there is RCA Sockets for Video & Audio out... generally Red & White & Yellow these go to the corresponding inputs on the camera's Video & Audio inputs, OR Correct adapter. The camera must have the correct A/V INPUT selected. Then start the VCR to "Play" the tape, and set the Camera to "Record" this will/should then record the output from the VCR to the memory in the Camera.
Aug 21, 2007 | Canon MV530i Mini DV Digital Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
71 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
