Question about Leviton MFG 103-01453-2SP ELECTRICAL WALL SWITCHES 3-WAY GROUNDING pack of
How to run wiring to an existing three way switch
    Guru:
  • 351 Answers
Here are the two most common wiring methods used for 3way switches ..
Posted on May 10, 2010
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
I needed to add another light fixture and mount the switch next to an existing switch to another light fixture. When i run the hot wire from the existing switch to my new switch for the positive and t
You can use a double switch, or make a '2-gang box' by adding another switch.
Copy following links for wiring multiple switches inside same box, and wiring double switch.
http://waterheatertimer.org/How-to-wire-switches.html#double
http://waterheatertimer.org/How-to-wire-switches.html#gang
Here is image showing 120Volt wiring inside main breaker box, so Hot Neutral and ground are clearer.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
Aug 23, 2012 | Home
2 gang light switch wiring diagram
I'm sorry, maybe I'm not understanding correctly and completely. First, I'm assuming you're installing a two gang box to replace an existing single. If not and you have two red and one black terminated to your existing switch, all you should have to to is; kill the breaker, remove the existing switch, get a couple spare pieces of black wire, just to keep things consistent, splice the three black wires together, terminating one on each switch, top or bottom doesn't matter, and carry one red to each switch. That's about as simple as I can explain it. From everything you've said, your black sounds like your hot wire, and your reds go to either light fixture. This installation should work for you hope this helps!
Aug 19, 2017 | Electrical Supplies
Dual receptacles (hot all the time) next to dual rocker switches. One switch controls a light, the other a disposal. I've got three black and one white wire ( ground). The post set up on the rockers...
What are you doing? I can't figure it out.
I think you have a new double rocker switch and you are trying to replace a double toggle switch and you don't know which side to put your wires?
The screws are color coded. Look at the screw colors on old and new switches and follow same pattern.
If this is incorrect, answer back and I will help.
If you are adding another circuit.
That means running a new wire into the box to power another receptacle box, or to switch another light fixture.
If this is the case, the best place to connect any new circuit is the existing receptacle.
Connect new black wire to brass colored screw
Connect new white wire to silver colored screw.
Oct 25, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I am replacing a 3 way light switch with a dimmer switch. The existing switch has the green ground, two black on one side and a red on the other. The new dimmer has the green ground, two red and one black....
There is no universal convention on the color coding of wires for three-way switches, other than green always being ground. Fortunately if you wire it wrong you won't hurt anything, it just won't work right. Two wires are "travelers", they run between one three-way switch and the other. The "travelers" were attached to opposite sides of one end of your old switch. From your description, one is red and one is black. (These two wires are interchangeable, except that in one position both toggles up or both down would ON. In the other position one toggle up and the other down would be ON.) The "third wire" was attached to the other end of the old switch and is black. If you can't tell by just looking at it which lead of the new switch is alone at one end of the new switch (and is therefore mate for the "third wire"), you can just try the combinations. Assuming you still know which black wire is your "third wire" there will only be 3 combos.
Jul 27, 2010 | Cooper Wiring Devices Three Way Grounded...
I have power running to a 2 switch gangbox. Each
As long as the power is running from the breaker panel to the switches rather than the fixtures then it should be pretty simple.
1. Run a new 2 conductor wire from the existing box to the new box at the top of the stair.
2. Install a switch at the top of the stairs.
3. Disconnect the hot wire that is running to the two existing switches and connect it to one of the two conductors running to the top of the stairs.
4. Connect the remaining conductor on the wire going to the top of the stairs to the two existing switches.
Note that if you want to be able to use the Dimmer function from the top of the stairs this will be much more complicated. You will need to put two new switches at the top of the stairs, run more wire, the new switches will need to be 3 way dimmers and the existing switches will almost certainly need to be replaced as well. The wiring will also be much more complicated.
Jan 09, 2010 | Lutron Claro Screwless 2 Gang Wall Plate...
WIRING DIAGRAM TO REPLACE (4) 3 WAY SWITCHES IN EXISTING WIRING. (1) SWITCH HAS 4 TERMNALS.
Look carefully at the box you got the switch out of.
A 4 way circuit normally sits between two three way switches. The 4 way makes and breaks the wires that ONLY travel between the two 3 way while the third wire on the three way is "line" or "load"
Since you are replacing an existing set of switches, pay attention to the terminals of the devices you are removing. You will see that the screws on the terminals have distinctive colors. Hook them to the new switches the same way.
Again, look carefully at the diagram thaat is on or inside the box
I hope I have not confused you with this explaination.
A
Oct 17, 2009 | Electrical Supplies
Leviton MFG 103-01453-2SP ELECTRICAL WALL SWITCHES 3-WAY GROUNDING pack of Logo
220 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
