Question about Jensen VM9410 Car DVD Player
The power botton is red but unit will not turn on and the screen displays nothing and its closed what should i look for when opening the device
    Problem Solver:
  • 13 Answers
You need to check that ign, and 12v constant wires are connected right
Posted on May 12, 2010
I have a bose tv speaker system. I have not used it in awhile. I cannot seam to get it working. the red light is on the remote device that sets under the tv.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Dec 14, 2016 | Bose Televison & Video
Soniq qv420ph no display
It sounds that the start signal does not comes from its main digital board to its main power regulator board. There is nothing a user can do with this fault. It will be best to contact any service technician. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 17, 2013 | Televison & Video
What happen to ricoh aficio display 542
A SC542 deals with the fuser unit, it's not warming up to the correct temp. Did you have a power outage? Try to rest it with pressing the "Yellow clear botton then the numbers 1 then 0 then 7 then press and hold the red stop/clear botton till the screen changes. Once it changes turn the main power switch off and then back On..... If it is not cleared you may have a problem with the fuser unit.... Good Luck
May 26, 2012 | Ricoh Office Equipment & Supplies
Erore code
You can try to clear it with " press the yellow clear botton, then the numbers 1 - 0 -7 , then press and hold the red clear stop botton, till the screen changes... Then turn the MAIN POWER switch OFF & then back ON. If that will not clear the code, then let us know what the error code is , that is displayed on the display screen.... Good Luck
May 24, 2012 | Ricoh Aficio 450 Copier
My New Garmin Nuvi 1400 will not turn on - it just gets to the screen "Loading maps" and then the screen goes black. I have tried the suggested holding down the power button for 10 seconds, but nothing...
My Garmin Nuvi 1490 was on for five or six hours driving then the screen went dark and now unit will not turn on or light up screen at all ? ANY HELP OUT THERE ?
Feb 09, 2010 | Garmin nuvi 1490T GPS Receiver
I have a reddy heater model blp55va and when I start it by pushing red botton it starts but when i let off botton the flame goes out.
Test the thermocoupler:
Normal 0 Heater will run as long as the control valve is pressed.
According to DESA test these parts. NOTE: Not all heaters are equipped with
A relay.
Thermocouple
Turn off gas supply. Remove thermocouple
from gas valve. Using a digital
multi-meter set to the lowest DC millivolt
setting (meter needs to have alligator clips
on ends of leads), clip black lead to the
very tip of thermocouple (end removed
from valve). Clip red lead to the outer casing
of thermocouple for ground. Relight
unit output should be between 18 and 28
millivolts.
Relay
Turn off gas supply. Remove bottom of
base (if equipped). Relay is a normally
open circuit between terminals 4 and 6
which closes when current is supplied.
Using a digital multi-meter measure the
resistance. With no power to unit, resistance
between terminals 4 and 6 is open
circuit or no resistance. Apply power to
relay. Resistance between terminals 4 and
6 should be less than 100 mili ohms.
Nov 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Nothing appears on the screen
press the power botton .
It might got into hibernate mode.
Dec 25, 2008 | Acer Aspire 5920-6727 Notebook
Help
HI SOUNDS LIKE THE RIBBON/FLEXI CABLE
try www.carradiospares.co.uk
Regards
Mark
Jul 31, 2008 | Sony CDX-M800 CD Player
Service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 03, 2008 | Computers & Internet
Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
May 04, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Jensen VM9410 Car DVD Player Logo
108 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
