My viewsonic VA912b goes thru a few minutes of a cycle upon turning on or waking up where it has a black screen, then a few seconds of normal display, then 10-15 sec of black, then a few seconds of normal, etc. until after about 5 minutes it finally stays on normally and is fine. The monitor makes a sound each time the normal display flashes on. Any ideas or just time to get a new monitor? This one is 3 or 4 years old.
  • Louis Ebert May 11, 2010
    smithelev381, May need to open unit and inspect printed circuit boards. Do flashlight test when "black" screen is present and you know that pc has booted fully to the Win-desktop. Can you still see the desktop?? Then do some reading in my and other fixya CCFL back-lit lcd technicians profiles (buddymc , budmrtn) for info to help you make decision to DIY repair or contract out the work, or just trade unit for new. Your VA912b no different than any other cold cathode fluorescent lamp back-lit lcd monitor in it's basic design and operation!! Follow the links you find in the profiles and you too may even be so happy you did, that you will DIY repair and also buy a new unit, keeping the VA912b as a backup unit. Yes, your unit may need just one "thermally-intermittant" solder-joint to be resoldered to restore it back to use. Have you been to YOUTUBE to view DIY repair videos of "lcd monitor disassembly" and "lcd monitor repair" ??? Hope this helped. 12fixlouie
  • smithelev381 May 12, 2010
    Thanks for the help. It had 8 bad capacitors. Watched the youtube videos which really helped know what to do. Total cost of repair was $18 and several hours of time. Monitor now works great!!
  • 11,361 Answers
Look for bad caps as shown in my pictures, common problem in all brands of LCD monitors.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA912B/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 10, 2010
Testimonial: "Thanks so much for the help! My son and I ventured into unknown territory in trying this. We opened up the monitor and sure enough there were 8 bad capacitors. We tried the local Radio Shack but they didn't have the right sizes so went to a larger town and found an electronics supply store that was very helpful in getting the right capacitors - they knew we needed hi temp ones which were a bit more expensive - it pays to ask for help. We took the bad ones out and soldered the new ones in and presto the monitor now works great! Total cost was about $18 plus several hours of our time but what a sense of accomplishment to fix something yourself! BTW the videos on youtube are very helpful if you don't know what you're doing."
  • Bud Martin
    Bud Martin May 13, 2010
    Glad to hear a successful repair works, it is not that hard if you have the right information.
Va912b monitor flashes on for a second then goes black, how can I fix it? I need immediate help.
Please see my pictures here if you are going to DIY repair: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA912B/
Common problem in LCD monitors, see other failed Viewsonic and other brands in my albums.
Please post back what you find so we can guide you further.
Apr 19, 2010 | ViewSonic VA912BWB 19" LCD monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
My monitor(Viewsonic VA912b) flashes on and then goes to a black screen. Anyone know what is causing this?
Could be a few things.
It could be the resolution settings.
It could be that your monitor isn't connecting to your computer. In this case you would have to get a card for the monitor to plug into.
It also could be that it's not supported by the OS.
Jul 11, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA912b monitor fading out during boot
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Jun 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
I have 2 ViewSonic N2750w and and they both have black screens
i have repaired several n3750w viewsonics .. that may be similar to the 2750 .. in my case all the failures were caused by the same faulty part in the power supply .. the power supply has a 48 volt supply at about 7 amps .. the design uses a syncronous rectifier .. these are normally not used in supplies with that high a voltage out .. syncronous rectifiers make sense when the output voltage is low .. like 3 or 5 volts .. the parts are designed for that range .. but in this supply an IC is over stressed and fails frequently .. you might hear a chirping sound as the supply cycles thru an overload condition .. i modified the power supply to eliminate the syncronous rectifier and replaced it with a single shottky diode .. dissapation goes up slightly but reliability goes up a lot .. i have written an article on this. if anyone needs it i will try to find it . ..
Jun 05, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
395 people viewed this question
David Payne
David Payne
