Question about HP Mini 1000 Netbook
WILL NOT BOOT UP GETS BLUE SREEN FOR A SECOND have reloaded windows 10 times works for about 1 wk then will not boot up
    Sergeant:
    Champion:
  • 236 Answers
It might something u use on there, or the version it self because those nbooks have solid slate drives so it cant be that
Posted on May 10, 2010
I have a dell opticplex gx620. It was working perfectly until the windows crashed. I have been trying to reload windows xp but once i press f8 to accept it will show blue screen.
You need an actual Dell windows disk to reload to a new hard drive as it will flash the associated drivers and boot sequence to the RAM. Nothing else works with DELL!
Oct 27, 2014 | Dell OptiPlex GX620 PC Desktop
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
0f00:065d
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 03, 2012 | Dell Inspiron Mini 10 Notebook
I have a HP tx2120 laptop and it seems to nly turn on once in a blue moon. The power is on but nothing comes up on screen and the underneath gets extremely hot. sometimes when it has been on for about...
this is the problem it needs reflowing. will not boot with this not connecting properly, and leaving this laptop on for long times like this it will shut down as you are cooking the board. and that will damage the board and other parts. might just be a better idea to change the board, if using windows 10 you need to install the original windows with the same windows key that your windows 10 was upgraded with or you will need to buy a new windows key.
Feb 01, 2018 | HP Pavilion tx2120US Tablet PC
Will not boot i keep getting the blue sreen
A blue screen means that Windows is corrupted beyond repairs. So, friend, you must re-install Windows on your laptop. the data will have to go as the recovery disks will per force install it in C:\Windows folder where your data is presently.
But before you resort to re-installing it,just once try booting the laptop in safe mode by pressing F8 at boot time. Select Safe Mode when the B&W age opens with choices. If it does not boot up now, then go ahead with reinstall process. If by any chance it boots up, the you can restore the Windows to an earlier date. To do that you must go to Start->Accessories->System Tools->Restore. here you will be shown restorable dates in bold numbers. Select any date that is before the trouble started. And let Windows do the job. The laptop will have to reboot once. after that it will become alright.
If not, (hopefuly not)hen reinstall Windows from the recovery CDs.
Dec 10, 2009 | Gateway Computers & Internet
Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
Jul 18, 2009 | Computers & Internet
My computer gets frozen at...
You would need to do a Fixboot. Assuming you have Windows XP.
1.Enter bios.
2.In boot tab select the first one cd/dvd and the second one HDD.
3.Open cd/dvd drive and put Windows XP CD.
4.Exit bios saving changes.
5.Press any key when prompt
6.When windows setup start at first boot press R to repair.
7.When black screen press 1 and enter.
8.Administrator password leave it blank or if you have a password enter it.
9. Press enter.
10.Then type this in the string. fixboot press enter.
11. Type exit press enter.
12.Take out the Windows cd and let it boot as normal.
Hope this help Thanks Let us know. Obed
Sep 05, 2008 | Systemax Neotach 3300 Notebook
Thinkpad R51 Blue screen
First:
does this also happen in safe mode boot. (press F8 just before windows boots). If not then go to your event viewer and check the messages at the specific time,hour messages. for example. computer booted at 23:30. in windows around 23:31:10 and then blue screen. Go to safe mode. and look in the logs what registered at 32:31:10(around this time).
If not possible to boot in safe mode. Try to remove one of the 2 memory dimm(if you have 2). so you boot with 1. maybe 1 of them doesn't work good anymore.
Nov 30, 2007 | IBM ThinkPad R51 Notebook
DELL GX260 bootup problem
To start with I would run FDSIK from a DOS boot disk and delete the partitions on the hard drive. Then reload the operating system. There is no telling what has been loaded on the system. After the reload the DELL should boot normally.
BPCS
Nov 15, 2007 | Dell OptiPlex GX260 PC Desktop
HP Mini 1000 Netbook Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
