Question about Toshiba Satellite A100-S8111TD Notebook
Wireless connection A100 Tosiba Dual Core having trouble keeping wireless connection, can only get it if sitting beside the modem. Where is the wireless on/off switch in case it has been accidentally switched off.
  • iq4u Mar 30, 2008
    I appreciate the advice however it has only just stopped reading well, I have used it succesfully for 18 months.
    We do share the modem in the house with a couple of other computers but never had trouble before.
    thanks again
  • COD outcasts
    COD outcasts Nov 28, 2008
    Bought the A100 for niece, college IT department reloaded XP, and now wireless does not work. NIC is fine. I'm looking at device manager, and assuming it's the 1394 Net Adapter? I just don't see the "view available wireless.." like I'm used to. Help! I have <24 hrs...Thanks!
    Linda
    Genius:
  • 1,027 Answers
You may have to connect the antennae for the wireless card. On my toshiba it is under the keyboard, it seems someone overlooked this small item during assembly.
On my other lapto it has an access door on the bottom,
Posted on Mar 29, 2008
    Sergeant:
  • 318 Answers
With the computer facing towards you - on the right side, first switch there (looks like a slide) is the wireless (on/off) switch.
Next after that is to check if any other wireless computer is reading your wireless signal - for it could be your modem/router.
Posted on Mar 28, 2008
SOURCE:
Vizio wireless router support
Try removing the power cord from the back of your modem and router and let it sit for 30 seconds to reset. Plug in your modem first and make sure it's fully loaded. Then plug in your router and wait 30 seconds to load and try again.
Nov 01, 2012 | Vizio Xwr100 Dual-band Hd Wireless...
How to make my laptop as a wifi device so that i can use internet on my mobile by turning on wifi in it??
You can't use your laptop as a wireless router.
If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jan 30, 2012 | HP Hewlett Packard 6535b AMD X2 Dual Core...
Modem-router connection
ur wireless Network remain unavailable cause may be u have kept it in hidden mode... check the settings once again inside the router
If the problem still persistes... reset the router and reconfigure the same.
Jan 06, 2010 | Computers & Internet
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
My AMD Athlon(tm) X2 Dual-Core QL-64 by Gateway has wireless network problems. When on wireless, there are lag spikes (meaning it suddenly stops working) every five seconds for around one second each time...
"under the same modem" .. you mean connected to the same router?
if you are using an external USB modem, try a different cable -and keep it short. I can't think right now of any clear causes of this problem other than a bad USB (or too long) cable (which can cause exactly this problem).
possibilities.. could be a cordless phone, cellular, wireless mouse/headphones/controller, bluetooth .. many of these devices connect with their receiver regularly and use almost identical fequencies which interfere.
Doubt it is a network conflict -where someone else has the same IP address. You could try setting a manual IP address too..
good luck!
Aug 31, 2009 | Gateway Computers & Internet
Wireless download in tosiba a100-590
download the drivrs for toshiba frm www.driverscollection.com
Aug 26, 2009 | Toshiba Satellite A100-S8111TD Notebook
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Toshiba Satellite A100-S8111TD Notebook Logo
358 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
