Question about Whirlpool ED5FTGX Side by Side Refrigerator
I have a Whirlpool ED22TE model side by side. It is running...but no longer refridgerates or freezes. I have vaccuumed all coils, still hot as ever. It came with the house that was built in 2002...so this is only about 8 years old...
  • 77 Answers
SOURCE: Whirlpool Side by Side Refridgerator
the heater in the gasket area is on when the unit is cooling (compressor running). hot weather makes unit run more, hence the heater is on longer and gets warmer. Coils under the unit being dirty or many door openings can also cause extra run time.
J
Posted on Jun 15, 2008
  • 833 Answers
SOURCE: refridgerator side of my refridgerator keeps freezing my food
The problem may be low gas or it may be the thermostat is set too low.  First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from..  Fridge side should read about 40 F after the door is closed for about an hour.  If colder, adjust.
Posted on Nov 15, 2008
esanto2
  • 3 Answers
SOURCE: Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
Posted on Dec 07, 2008
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
  • 306 Answers
SOURCE: Freezer won't freeze
remove rear panel in freezer and see if ice an frost is there. if so defrost heater is kaput or the contollers for it.
Posted on May 05, 2009
Refridge temp
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Sub-Zero 642
Subzero refrigerator freezes
Apr 30, 2012 | Refrigerators
Its running cool, But not cold, and will not freeze, the fan is running, the compressor is very hot,, I thought it might be that defrost bar, in the evaporator was not working, which would mean its...
Not cooling compressor running... Verify fan by compressor is running. Verify doors are sealing.
Are Coils are hot in the back by compressor? Clean exterior coils.
Jul 19, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirpool side by side refrigerator hot door gasket
Good day,
The first step is to clean the coils properly. Remove the back cover, and make sure the cooling fan is running. At this point, unplug the machine and with a wand and a push pull vaccuum blow the dirt out of the coils from back to front.
Yes , it's filthy and ugly, but the only proper way yo clean it.
Make sure the cover in the back is properly reinstalled. (See my tips). At the beginning, the divider will be fairly hot, but should slowly cool after enough running time to get the machine to it's normal temperature.
Apr 30, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerator not cooling but freezes
You might try vaccuuming under the frig to clean the coils so it could disapate the heat more. This could cause that sytem. Also if the fan is not working.
Hoped this helped. If not let us know.
Mar 16, 2009 | Maytag MZD2766GES Side by Side...
The refridgerator runs but does not cool or freeze anything. There is a clicking noise everytime it tries to cool.
sounds like the compressor has seized and the click is the relay starter to get it going. if it is running and getting very hot the likelyhood is that there is a refridgerant leak.
Mar 13, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refridgerator side of my refridgerator keeps freezing my food
Nov 15, 2008 | Refrigerators
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Whirlpool ED5FTGX Side by Side Refrigerator Logo
405 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
