Question about Dell Latitude D505 Notebook
No Opening - The computer center control cover (A) continals to flash for 10 Seconds only
Pressing the power bullon to start the computer the three green lights frash (9) (A) (I) however the (9) and (l) swith off, the (A) light flashed for ten seconds and then the system powers off. No screen action or any thing presents.
Many thanks for any help.
Dean.
  • 1 more comment
  • Dean Price Mar 28, 2008
    I have had the system on full charge with two different cable charges.
    The battery charger only flashes when on charge it does not stay active when on charge. Have you any idea.
    Thanks mate.
    I note that two different power cables have been utilized with no success, also I have tried two different powered batteries and it still wont alter the fault. Whne on charge the power charge light only flashed every couple of seconds, it does not show continual power connection/chargeing.
    Any further ideas mate?
  • LISASP May 19, 2008
    I'm having the EXACT same problem. I contacted Dell they said the blinking "A" light is an indicator of a memory problem (though they first suggested a faulty system board). I purchased a brand new memory, swapped it with the old, and the problem still exists. I KNOW it's not the power cord as the adapter shows a solid, green charge and I tried to dock the laptop but same problem exists. Were you able to fix your problem? If so, PLEASE share how?
    Sergeant:
  • 313 Answers
Make sure your power cord is pluged in and the indicator light in front is yellow (saying that it is "charging") - these cords are known to go bad quite often.
Your computer is saying there is not enough battery, or power to keep it from booting all the way up.
Posted on Mar 28, 2008
  • Hollyecho Montgomery
    Hollyecho Montgomery Mar 28, 2008
    When did this start happening? All indications are still pointing to power (or lack thereof). Could be a cable or connector inside not connecting properly, only last week I had to soder the power connection to a motherboard for a client.
    It is easier to test the connection with a power adaptor than it is a battery connection, (i know this will sound silly and non-productive, but give it a try) - try holding and "adjusting" the cable when it is pluged in to see if you get a solid light instead of flashing.
Why won't my PC power-up?
Firstly you should not unplug your computer for long times. Inside is a battery to keep the BIOS alive. When you unplug it, it flattens the battery and if left unplugged for a long time, it kills it. This means that the BIOS now starts in default mode, which can lead to many problems because all the custom BIOS settings are now lost forever or until you or someone else change them.
Change the battery on the motherboard and try again.
The reason why the LED was flashing then stops, is that the battery has a small charge enough to be stable. Now that your BIOS battery is dead, you will never be able to charge that battery again, so replace it.
Sep 01, 2014 | Watches
Dell latitude D600 problem
plz repair or reload the operating system
Jun 30, 2008 | Dell Latitude D600 Notebook
The control panel is flashing a L. What does this mean?
Hi.
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
My dishwasher will not start its cycle
Is there power to the dishwasher?
electricity ground dishwasher.
Connect ground wire to green ground connector in terminal box.
Donot use an extension cord.
Failure to follow these instructions can result in death,fire,or electrical shock.
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
My dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Feb 12, 2010 | Dell XPS M1530 Laptop
Flashing engine light on a 2000 FLSTC Heritage Softail
You should have your engine codes read to pinpoint exact problem location. It may be faulty sensor or other electrical problem or leaky vaccuum
Aug 25, 2009 | 2000 Harley Davidson FLSTC Heritage...
Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Nov 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Dell Latitude D505 Notebook Logo
170 people viewed this question
Alun Cox
