Question about Saws
When i use my worm drive Skill saw sparkes shoot out of the rear vents?
    Brigadier General:
  • 4,088 Answers
Check the brush spring tension. If the brushes become bound in their slides due to carbon/dirt/sawdust, the brushes will tend to arc and when they do, they create extra heat which tends to collapse the springs. Pull each brush out noting the wear pattern on the end so that it returns with the same orientation, clean the slide out with a small round brush so that the brush moves smoothly, check the spring (it will be bright brass if ok, but discolored if overheated), then replace the brush. Do the other one similarly. This usually fixes this problem, but will reoccur over time. Hope this helps!
Posted on Jun 21, 2010
I replaced trigger and brushes on my worm drive skill saw and it won't work.
Could be broken wire in the cord itself. Before it gets to the switch
Nov 15, 2013 | Saws
How to dry out a skill saw that has been in water?
While running, Spray (into the vent intake) silicone lube spray.
Oct 04, 2013 | Saws
Skill Wormdrive HD77 saw sparks are coming off the brushes
you have a problem with worn brushes or the armature might be failing. UNPLUG the tool and remove the brushes to check their condition length and look at the face of the brush for any unusual wear. Then look into the brush tubes themselves and slowly rotate the armature for discoloration/raised commutator bars.
Jun 23, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
What kind of oil do i put in my skill saw 77
This saw requires Skil's heavy-duty, worm-drive oil, part number 80111. If you can find a local vendor that has some great otherwise, type 'skil 8011' in your search engine and shop around for an 8oz tube, they can run from $5 to $10 plus shipping.
Jan 28, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need to know what kind of oil do I use to change the oil in my skill saw 77? Mine is pretty dirty, runs great but thought I should change the oil. Thanks Bill
Use Skil worm drive oil #80111 ($5-$6.00) at Home depot, or Bosch WD7LUB 2.3 FL. OZ. (I bought for $3.50 at Bosch service center.)
Aug 28, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need to know what level oil in my skill saw mag77 should be?
have the saw as level as possible and put in oil until it starts to run out on the bottom of thread. Make sure you use a worm drive oil, just any oil will not work properly.
Mar 28, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
What is the square cut out on the ryobi ets 1526 for?
Certain saws such as the Skill worm drive have the matching drive hub for that punch-out in the saw blade.
Nov 09, 2009 | Ryobi Circular Saw W/Dual Laser
Skill saw
its on the front, the opposite side of the trigger.
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
577 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
