Why does my monitor screen automatically black out after approximately hal and hour.When I reboot soon after the screen remain black but would work after half
-   My Fujitsu Siemens monitor blacks out after half a second when I try to reset/ turn it on, it's been doing that for about a month now. If I finally get it working I leave it on overnight and it seems to remain intact as long as I don't reset or shutdown.
-   Guest
Dec 04, 2008
-   I have the same problem as already described. The monitor will work for a while, then go black. It was only 1 year old when this started.-   Guest
Oct 25, 2008
-   has anyone fiqured out how to resolve this issue. Mine does the same thing. it first started when the remote stopped working then is progress to inadvertantly turning itself off and on. What to do?
-   yearsleyd
Oct 13, 2008
-   I have a Philips 180mt The screen blacks out periodically, wheather it is on TV/PC. There is still power in it and all 'cause the light just blinks. -   mijtav
Oct 13, 2008
-   My 180mt blacks out intermittently. Sometimes I can use it for a while, but then the problem pops up again. The light just blinks and the screen is black.-   Guest
I have a 19 inch acer with a black screen but the small green light stays on, even if I reboot it won`t come on, I open the back panel and saw 2 boards, I wonder which one went bad and where to order the boards?
screen coming up off centre - halfway to the right; big black area on left of picture, right half...
(More)
screen coming up off centre - halfway to the right; big black area on left of picture, right half not visible. Can correct using monitor buttons but need to do every start-up.
My Hp F1903 monitor started going out several months ago. I I cut the power to the monitor it will work for an hour or so before going black. If I reboot it may work for a socond or so. I have to cut the power to it for a day or so before it will work again. I thiink it has to be a capacitor but I am not a guru that can fix such things withou a lot of help.
Thankyou
Jerry
Comment by Guest, posted on Aug 18, 2008
my screen keeps blanking out and when i turn it back on it works
After turning on monitor and computer boots up monitor will go blank with the green power light on. Have to turn monitor on and off at least 15 times before the monitor will have a display. Monitor is Dell E153FP
Comment by Guest, posted on Apr 21, 2008
I have the same problem whit my Fujitsu Siemens 900P.
After + - 1 hour the screen turns black.
After reboot sometimes he will be back a again but normally after letting the desktop out for 1 hour it will funktion again for a short time....
