Question about Traxxas T Maxx 3.3 Monster Truck
Truck wont start carb out of tune - Traxxas T Maxx 3.3 Monster Truck
  • 56 Answers
First of, trims in neutral there should be about 1mm opening of intake on carb. Top end needle should be back to factory setting which is 3 to 4 turns out from fully screwed in. Start engine and keep trying to start while turning top end screw in a touch every 5 to 8 pulls you may need a little throttle to help.
Posted on Aug 09, 2010
Wont stay started
your tuning is too low,try adjust your carbs tosired point,check fuel filter.if its blog drain it with gas thoroughly then fitted back,start the engine,revs at 1- 5 rpm.if theres no changes, bring your car to your nearest spare parts guys .they will help you out.
Dec 24, 2013 | 1988 Nissan Sentra 2 Door
My bike wont start I replaced spark plug
most likely carb setting. Try turning the carb set screw all the way in and back out 1 1/4 of a turn. then adjust by 1/4 of a turn to fine tune it.
Aug 05, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
Kdx 125 standard carb settings
DEPENDING ON WHICH SCREW WAS TURNED MAKES A DIFFERENCE..BUT RULE OF THUMB IS ALL THE WAY IN NOT TO TIGHT JUST FINGER TIGHT..YOU SEE THOSE NEEDLES HAVE A VERY FINE POINT ON THE END AND IF THEY GET TIGHTENED TO HARD THE POINT GET FLATTENED OUT AND DESTROYED..SO IN FINGER TIGHT AND OUT 1 COMPLETE ROTATION AND A 1/4 TO 3/4 OUT.BOTH SET SCREWS THIS SHOULD GET THE ENGINE RUNNING GOOD ENOUGH TO TUNE..PS..IF YOUR ENGINE DOSE NT AT LEAST ACT LIKE IT WANTS TO START ONLY TRY THREE OR FOUR TIMES IF NOT RUNNING ADJUST AGAIN BUT LITTLE INCREMENTS AT A TIME..NO THROTTLE NO CHOKE..DONT WANT TO FLOOD IT BEFORE IT STARTS..WHEN FLOODED IT WILL NOT START AT ALL..THE BEST WAY TO TUNE A CARB IS WITH A FLOW METER..
Jun 21, 2013 | kawasaki KDX 125 Motorcycles
My 1989 chevy suburban wont start; it is engaging but wont fully start. My battery is good, just did a tune up. Dont know what can be the problem
Have you checked fuel pressure at the injectors ?
Can you spray carb cleaner in the throttle body and get it to start ?
Is the spark strong at the plugs ?
Was it starting before the tuneup ?
Jan 11, 2013 | Chevrolet Cars & Trucks
My 99 yukon wont start when its cold, I can spray carb cleaner in the throttle body and it will fire,but other wise it wont start unless its warm.
When is the last time you had a tune-up on your truck? During the cold winter months, if the battery does not have a proper level of cranking amps it is sometimes hard for the engine to turnover in the cold. You may need a tune-up or battery replaced.
Nov 30, 2010 | 1999 GMC Yukon
How to tune twin carbs on a mini from start ? the car wont start unless i use easy start then runs rough and wont idle im not to clued up on these 14/ su carbs any tips? its the old one not bmw
First***Stop using starting fluid*** It will destroy your engine.
To set up the carbs, you will need to buy a vacuum balancer. This is a device that will show you how much downdraft each carb has. You then, have to adjust the linkage, so that they are the same. After that, you will need to adjust the fuel mix.
All in all, if you're not experienced in this, it is best left to a carburator shop, not most garages.
Sep 01, 2009 | 2000 Mini Cooper
Homelite backpacker blower # uto08083 not running
fist thing is run both the carb screws all the way in then back them off 1 1/4 turn this will be your starting point then start the blower to fine tune the carb if it starts then your carb was off giving it to much or to less fuel
Dec 20, 2008 | Homelite Consumer Products MightyLite...
Car starts hard chugs going down the road
sounds like timing and tuning. or the carb is sticking
Dec 09, 2008 | 1999 Pontiac Grand Prix
Traxxas T Maxx 3.3 Monster Truck Logo
164 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
