Question about GE JKP27 Electric Double Oven
Kitchenaid superba single convection oven flashing F1 E2U
  • Debbie Deeds
    Debbie Deeds May 10, 2010
    we had to replace both the board and touch membrane, each time (2x's), it shows the same code, and does not respond. .
    President:
  • 949 Answers
Hi, The F1 E2 code refers to the ERC (electronic control) failure. The fix would be the replace the control board. If you can send me the model number from the tag on the oven I can send you the part information you need for your oven.
Posted on May 10, 2010
  • Philip May 10, 2010
    Have you checked the power going to the oven?
    I am wondering if there is something from the line coming in causing the failure
    Another thing that can cause the control to fail would be excess heat. If the door is not closing properly or sealing the heat can be pulled into the cavity area. Also if the vents are dusty or blocking air flow this could cause over heating. Can you send me the complete model number from the tag and I can look up to see if there are any issues with this unit.
    Thanks!
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
I have a kitchenaid Superba convection oven. I be something else?
it sounds exactly like an ignitor, if u want the original ka part u will pay more,, you could use a 12400035 ignitor, or a sgr403, depends if its round or flat, go to repairclinic.com and enter those part numbers in to see pictures of those, or look up a ka ignitor and compare prices. hope this helps let me know whut u think
Feb 12, 2010 | KitchenAid Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
How to set the temperature on the KitchenAid Superba oven/convect
A separate oven thermometer is absolutely necessary in baking. Something similar to this would be cheap and easy. http://www.bedbathandbeyond.com/product.asp?order_num=-1&SKU=10161738
Or you could go for a digital one with a probe.
Apr 08, 2009 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
144 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
