Question about Elmo Projectors Elmo 70MM-125MM Pro Zoom Nine Group Lens
Looking for (free) instruction manual for Elmo FP-C projector
Instruction manual - Elmo FP-C Projector
2 Suggested Answers
SOURCE: I am looking for an instruction manual to
I am looking for an instruction manual to RE-assemble the lens of an Elmo projector FP-A. Can you help me? My email is dlbac@hotmail.com
Posted on Dec 16, 2010
Where I can find a service manual and maintenance for a projector Elmo FP-C?
I "Googled" the projector name & found service documents for it at: www.photobooksonline.com I hope this helps!! Jim
Feb 18, 2013 | Office Equipment & Supplies
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
Chords needed for elmo 400af
You are a teacher, and you don't know the difference between a chord and a cord ? Amazing. I think anyway you mean a lead - the one you require has a plug on one end to fit the projector, and a plug on the other to fit the camera. Look in the respective manuals.
Jul 17, 2017 | Elmo Projectors Elmo Ev-400 Af Video...
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
I can not turn the light on my super eight projector. I have changed the projector bulb with no success. All other features of the projector function properly. The projector is made by elmo moder FP-A
I would use a volt/ohm meter to test the bulbs, If they are known to be good, open up the projector and look for a fuse.
BTW- Elmo was purchased by Canon many years ago.
Jan 02, 2010 | Cameras
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to...
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Mar 10, 2009 | Fuji Photography
Cameras Logo
365 people viewed this question
Top Elmo Projectors Cameras Experts
Are you an Elmo Projectors Camera Expert? Answer questions, earn points and help others
