Question about Canon PIXMA MP600 all-In-One InkJet Printer
No blue color feed
I have used all cleaning apps but no help there.
  • owrosi May 10, 2010
    first thing i tried
    tried this first
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 74 Answers
You need to refill the blue cartridge or buy a new one. The cartridge is CLI-8C
Posted on May 10, 2010
Color wiring diagram
with the 5.4 engine
violet/white--- tps reference
gray/white ------ tps 1 signal
orange/lt. blue -- tps signal return
gray/red ----- signal return
red/white ---- reference voltage
with a 6.0 diesel
tan--------ref. volts
yel/white- apps 1 signal
blk/org---- signal ret.
white/red- apps 3 signal
gray/blk--- apps 2 return
white------- apps 2 signal
blk/white-- aps2
hope this helps
Mar 26, 2014 | 2006 Ford F-250 Super Duty
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
A band across the largeprint in the center is not full color. It has a blue tint like too much blue.
It sounds like it could be a bad nozzle on one of the feeds, try cleaning it with a rag or a proper printer cleaning kit. Also reinstall the software. If that doesnt work i would check with IBM tech support.
Jan 12, 2011 | IBM Infoprint Color 1464 Laser Printer
When I print blue horizontal lines appear or being printed as wel
Do the cartridges ride on the printing carriage, or do they plug in somewhere else in the machine and have hoses that run the ink to the print head? If they ride on the printing carriage and the cartridge is new, there could be a short in the printer and it needs repair. Check if there's ink smeared on the print head or part of the printer. Generously clean the print heads with lots of paper towels and rubbing alcohol. If that doesn't work, to see if it's an issue with computer, print a test page from the printer, but don't send the print job from the computer. You need a print job generated from inside the printer itself. Not every printer can do this, but try pressing paper feed, holding down paper feed and power, or holding down cancel and power. If the blue lines disappear then but they didn't when you cleaned the heads, it's a software issue.
Sep 17, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
I test ink and clean it at list 10 times change the blue I get abot 30% blue on the test. Can you help? AM
Had the printer sat for a long period of time since it's last use prior to having the problem? If so the ink may have dried up in the feed from the cartridge. If this is the case remove the cartridge and try cleaning where the ink feeds with a Q-tip and some rubbing alchohol.
Jul 18, 2009 | Brother MFC-440CN InkJet Printer
2001 Ford E-150, year 2001, wire harness connection
As for the head units leads they should be marked or identified in the installation manual. There are but only three wires here that I might be able to help you with.
Two of the wires should have in-line fuse links (12+ volt power) and they are the constant feed (for memory) and the switched feed (for operation). The ground lead is typically solid black.
This is a general factory radio color code. Wire colors in your car might be different than colors described here. Use the given colors for reference purposes only. Always test wires to make sure they are correct.
Good luck
Aduz
FORD P o w e r Memory (+12v Constant) Green Yellow Ignition (+12v Switched) Yellow/Black Ground (-) Black or Fat Red Illumination Orange Dimmer Orange/White Power Antenna Blue (varies greatly) S p e a k e r s Right Front (+) White/Green Right Front (-) Green/Orange Left Front (+) Orange/Green Left Front (-) Light Blue Right Rear (+) Pink/Blue Right Rear (-) Green/orange Left Rear (+) Pink/green Left Rear (-) Pink/Blue
Mar 28, 2009 | Car Audio & Video
Printer not printing
find the maintance section of your print driver display ( far right of the display ) should see a maintance tab.
do a cleaning cycle or a deep cleaning cycle and see what happens. it should start printing.
if necessary make up a solid single color block on a windows word doc using the squares make them no line perimiters and do a black blue red and yellow about 1/2 inch tall and 7 inches wide
as a test pattern. the color that doesnt print is clogged
in the future try not to let the inks run completly dry before they are replaced.
if that doesn't help use isoprople alcohol 91proof on a cotton swab or clean cloth and let the print head soak in it for 5 minutes and try again.
Feb 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Color ink not printing
Ahhrgh! Don't use windex. It contains additives that can harm the printer head.
I suggested this site in another post and it could help you.
Sep 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
