Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Printer stops job after print option chosen
Even when jobs are started again, it continues to stop the job over and over
epson stylus photo 875 DC
  • 4,041 Answers
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 10, 2010
Epson 9880 prints half a job, then stops
i aint too sure if its the same but i had an epson printer with the same problem last year it would print half a page spit out and then print the same half a page again and just stuck in a loop even on printing disks it did the same i found out after by speaking to a printer specialist it was the printers eeprom which is the printers memory bank that was failing and nothing can be done with it
Feb 11, 2014 | Epson 9880 stylus pro Printer
Can't print a cd on epson stylus 1400. The printing queue says paused.
right click on the print job in the queue, and click "restart". Other wise try this:
If you've ever had a print job hang, you're probably familiar with the Windows Print Spooler window. You get to this window simply by selecting the relevant printer from the Control Panel's Printers and Faxes applet (simply Printers in Vista). In the somewhat unusual event of a printer queue jam, you can go to the Print Spooler and simply delete the job. Sometimes, though, the system won't let you cut off print jobs that way: It marks the job "Deleting..." but never quite gets there, and you end up rebooting. But there's an easier way.
Open a command prompt (go to Start ' Run, then type cmd) and enter the following:
net stop spooler
del c:\windows\system32\spool\printers\*.shd
del c:\windows\system32\spool\printers\*.spl
net start spooler
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator. For those of you who remember batch files, use Notepad to save the four commands above as a batch file. I've named mine Killqueue.bat.
Dec 14, 2010 | Epson Stylus 1400 InkJet Photo Printer
Wep lq dsi 5235 how to cancel print jobs immediately
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Epson Stylus Photo 1410 Printer
GREEN LIGHT KEEPS FLASHING ON MY PRINTER
Green light flashing means printer is in printing process. No problem. If you want to stop printing. delete printing job from printer properties or stop printing from status monitor.
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Long Lag between Print and Printing (sometimes)
Hi ,
Please perform this below trouble shooting steps:
1.Check whether printer icon is in Online or Offiline If it is Offline right click on it and select Use printer Online. then try to print your issue should resolve.
2. On computer Click on Start >> Run >> type cmd >> then press enter black window appears.
now type as below
net stop spooler
net start spooler
now try to print.
if issue still there perform next step
3 Right click on the printer Click on Properties >> Advanced >> Select Print Directly to the printer your issue should resolve.
Feb 18, 2009 | Epson Stylus Photo R300 InkJet Printer
Can't delete print job for an Epson C** printer
I don't know which OS you have. I will assume it is a newer OS like WinXP. You have tried to reboot the PC I'd imagine. Try stopping the print spooler by running the following command from the cmd prompt.
net stop spooler
Then check the print queue and see if you can manually delete the print job. Then issue the command
net start spooler
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson stylus 600 non stop flashing light nonstop printing
Flashing light may indicate that it's receiving data to print.
What is it printing?
Cancel all print jobs.
Nov 19, 2008 | Epson Stylus Color 600 InkJet Printer
"JOBS STOPPED"
dear g-gal
Please reinstall the driver for the printer
Apr 07, 2008 | Epson RX620 All-In-One InkJet Photo...
Printer stopped working claiming the jobs have been 'stopped' and giving no explanation.
Hi Plug out the usb cable from the cpu. Try deleting the printers from the printers window(START, Printers and Faxes), uninstall the software. Power off the printer and unplug power adapter. After the printer has been deleted from the printer window, plug it back in and reconnect back to computer. Then try a new installation of the printer and software. The pending documents that have been stopped should now not be in the spooled documents.
May 02, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Job stopped!
hey wildd, Try unplugging the printer from the electrical source for "several" minutes. Shutdown the computer too. Turn on the printer, then turn on the computer. If that doesn't work go the whole mile. Uninstall all printers and software. download the latest drivers from Epson. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23952&infoType=Overview This link is to the epson site and your machine. Download the drivers from here. Have you had any paper jams lately? Make sure there aren't any pieces of paper stuck or any other debris. How about the print properties, or open print jobs? what does it show when the job stops. Let me know what happens. Good Luck, Tim
Mar 13, 2007 | Epson Stylus C64 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
