Question about HP (5185-6477) Motherboard
Motherboard problem - no image display when turn on
Hello im wan,
I just replace the heat sink bracket attach to motherboard, the problem is when i assemble all back & on my pc, there is no image display from monitor, how can i solve this problem? please help me....
  • Haswandi Asrul Mar 28, 2008
    Thanks, Ok i have done it, but still no image & no beep, proc fan work fine, my PC model HP Pavilion a526d, motherboard MS6577, any other suggestion? pleasee...
    "while fixing see to that the RAM locks in the slot correctly." i don't understand, sorry im new to technical, i have done with the rubber & clean the bottom part of the RAM, but if i remove all RAM there is still no "beep"?
    Guru:
  • 1,894 Answers
Please fix the processor fan properly.
this may not allow the processor to start
Posted on Mar 28, 2008
  • dewan nafees ahmed Mar 28, 2008
    NO BEEP huh??
    that is the problem..
    that is due to the RAM problem only. remove the RAM and use a white rubber too clean it and then fix it.
    u can do one kind of test to find if there is any problem till RAM stage
    if u start the system without the RAMs then after a few seconds or a minute u must get continuous beeps.
    that means RAM is missing.
    if you are not getting even continuous beeps then problem still lies between the RAM and processor.
Hello, I just added an additional internal hard drive to my Gateway DX4200 desktop. To do so I had to remove the CPU to slide the drive into the bay. PC will not boot (fans power up but no...
Take your computer to a tech savvy or support shop so they can make sure your CPU isn't damaged. If it isn't they can reattach it with new CPU coolant on it before the heat sink goes on.
And don't touch the seat arm. That is for the CPU itself. The rest (fan and heat sink) can be attached differently.
If you haven't done this type of work before I would recommend you go to a store and have it fixed and if possible look them over the shoulder for future knowledge.
Jul 16, 2017 | Foxconn A6VMX Socket AM2+ AMD Motherboard...
My old heat sink and fan have screw in attatchments and the new on has the plastic pop in and 1/4 turns. Help?
Your old heat sink and fan probably works just as as good or better than that stock Intel fan and heat sink. If your computer case does not allow access to the rear of the motherboard you are going to have to remove the motherboard to pull the back plate that was used to attach your old heat sink and fan. To install the Intel fan turn the pins until the screwdriver slot is perpendicular to the fan shroud (the tip of the arrow is furthest out), then push in any 2 opposite sides at the same time into the motherboard. You will here them click in. Repeat for the other 2 pins.
Dec 22, 2010 | Intel Socket 775 Heat Sink and Fan up to...
Hello. This computer will recognize a good
This is the problem with the display capacitor on your motherboard. Try replacing the display capacitor by good technician. If it doesnt solve your problem you need to change the motherboard. But mostly this will solve your problem.
Oct 15, 2009 | HP (D9820-60007) Motherboard
Square "comb-like" box came unglued from motherboard
Assuming that you are talking about the heat sink.
This device actually makes contact with the CPU and is held down, usually on four points, to the motherboard.
You will need to get some new CPU grease to put between the heat sink and the CPU when you re-attach the heat sink.
However, I would first examine the heat sink to verify that the "legs" are not broken. If they are, you will need to purchase a new heat sink.
Also inspect that the motherboard isn't broken. It normally isn't but you never know.
Good luck
God Bless
-Carlos:
Jul 01, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Algerian-47
you could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Jul 01, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Heat sink fan P4VMM2 v 3.2A
Which one of these CPU's are you using?
Jun 17, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Heat Sink Fan fell off
Any Pentium 4 fan will do. The pc will not boot without a CPU fan plugged in.
Jun 17, 2008 | EliteGroup P4VMM2 Motherboard
Reinstalling a pentium 4 1.7ghz onto motherboard
donot attempt to install cpu with heatsink attached, detach and install.
Dec 13, 2007 | Computers & Internet
HP (5185-6477) Motherboard Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
