Question about OKI B2200n Led Printer
My Oki B2200 is repeatedly showing Toner is empty. The waste cartridge is full of toner. I took the toner in the waste cartridge and refilled the toner cartridge. Now it wouldn't print even after I open the cover to reset it.
  • 4,041 Answers
Hi there
I not know your printer but I can say this that after refilling it your chip will still thing it emty so some where on the printer Menu there is a way to reset the it back to 0 so it starts like new again.
Sorry cant be any more use to you than this, try looking up the net or the manual to how to reset.
All the best : Pineworks
Posted on May 10, 2010
How to reset oki b411dn cartridge after refilling
Producers of printers protecting oneself against the mass copying of original toners implemented the number of solutions being aimed at hampering the copying of their solutions. Towards a number of recipes for individual sub-assemblies of the cartridge intended for a laser printer applying special scaling circuits installed in the casing of the toner which are suming the number of printed sides up was the most spectacular solution and are freezing the laser contribution after the achievement of set limit of printouts. Toner do drukarki materiay eksploatacyjne Chip toner co jak
Apr 23, 2014 | Oki Electric Industry B411dn Printer
Oki c5650 toner showing empty but it is full
first open the cartridge access door and look inside the printer is there any toner dust or not? then manually inspect the optical white fiber hole is clean or not.and finally inspect is there any cartridge detection chip if yes then replace the chip your problem will be solved.
Jun 15, 2012 | OKI Office Equipment & Supplies
I have a problem in my oki b2200 printer.he does not print.when i was print page then one errer show."your toner empty.and other side printer give us beep orange light
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Apr 25, 2011 | Computers & Internet
Help with toner reset problem on OKI B4600. After refillig cartridge, on display apears "Tonner Empty - Replace cartridge"
Go to the maintenance part of the printers program and clean the heads is the job to perform. The run a test page for alignment. It will adjust back correctly showing you have ink
Feb 26, 2011 | OKI B4600 Printer
Samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
Dec 22, 2010 | Samsung CLP 315 Laser Printer
Waste toner gets full before toner runs out
Actually, the waste toner should get full sometime before the regular toner runs out in laser printers that have several toner cartridges compared to the single waste toner reservoir.
You can dump the toner reservoir out and avoid buying the empty waste toner 'reservoir.'
I did this on my Brother Laser printer and saved about $30 or so for an empty plastic waste toner bottle or jar.
If this is the way the Kyocera-4020DN is, then I would put the waste toner, which is just that, waste, and put it into a plastic zip loc storage bag and throw it away. Don't breath the toner.
Good luck on this repair.
Jul 19, 2010 | Office Equipment & Supplies
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
I need to clean out my Laser printer - OKI OL 400EX
I replenished the empty toner cartridge using the contents of a reduced price (from PCWorld) cx-OKI400l-is cartridge. For this you need a steady hand and a very small, very shiny stainless steel funnel. These are available from a good kitchenware shop. There is a removable cap to the cartridges. I understand one should only use the Toner from a cartridge by the same manufacturer as the printer. My old OKI OL400ex is now working again. I still don't have the answer to: Where does the excess Toner go? Does it fill up the printer drum? Michael UK
Jan 22, 2010 | Office Equipment & Supplies
Toner level
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Jun 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Oki c9600 printer - waste toner box
Sometime the white round spring action mechanism on the printer breaks which causes the toner box warning This mechanism connect to the printer toner box when installed.
Feb 20, 2009 | OKI C9600hdn Laser Printer
OKI B2200n Led Printer Logo
3,072 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
