Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Tractor Front end loader will not dump. JD 2320 tractor front end loader .
  • 333 Answers
Could be a lot of things. Quoick coupling loose? Does the lever work from left to right? Is it stuck now and only work from front to back? There is a small lockout feature on it that keeps from it moving when you hit it with your legs. It is down at the base of the lever. Other than that has to be connections. Try swithching the hoses around where up and down is dump.
See if its that
Posted on May 11, 2010
I have a John deere 2320 compact tractor with a H130 front end loader. Bucket will not stay tilted downward when trying to scrape material down off a pile of snow or dirt. Any thoughts as to a fix
the return valve or tilt back control is allowing oil back and not locking the bucket in a set position so that when pressure is applied as in lifting ( moving backwards to smooth out) that oil in the cylinder is not held in check
check bucket controls and valves
Jan 31, 2016 | John Deere Garden
John deere 1020 front loader stuck in raised position will not dump or go down with gravity
Full full Up... hmmm sounds like the Cylinders are slightly c ocked and bound up.
Apr 05, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Loader stuck in raised position
Check your hydral fluid
Apr 05, 2014 | Garden
JD mighty mover tractor, 27MHz, 3 function remote 1. forward/reverse, 2. left & right, 3. loader bucket up/down Problem: no forward or reverse, front wheels turn left and right just fine, loader goes...
My son and I took apart the toy as we have the same problem with ours. The green terminal on the motor moves when we apply pressure to it and the motor speeds up considerably. It appears that a weak or bad terminal is the cause of loss of power. We are not sure how to maintain the pressure on this terminal.
We are going to put it back together and see if it works.
Apr 23, 2011 | RC John Deere Mighty Mover Dump Truck
JD 301 industrial loader tractor Overheating
You may need to do a compression test on the engine to confirm whether or not the head-gasket needs to be replaced,that's where i would start if the thermostat is not the problem and the hydraulics are not loading up.Check for oil in the radiator or anti-freeze in the oil as well as for white smoke out of the exhaust,all are indicators of a bad head-gasket.
Jul 17, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
334 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
