Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
LOW FLAME Hello We have a parkinson cowan stove and we seem to be having problems withe main oven, the flame is so low we are unable to cook our meal in there we have to be using the top oven. Any ideas why this could be happening, there is flames but very low. Thanks
  • Anonymous Jan 25, 2009
    I recently bought a second hand Parkinson Cowan Lyric cooker in good condition but when it was connected to the gas supply the flame was so low that ithe four burners kept going out , the grill only spluttered and kept going out and the oven would not light at all. I have checked out the new supplyhose and there is nothing wrong with that. Please can you help.
  • 53 Answers
it sounds like something may be blocking the burner tube.
if you can, remove the burner tube and use a long brush or compressed air to clean it out. if you see black soot on it be careful it can make a HUGE mess, and soot is a sign something else may be wrong.
Posted on Mar 30, 2008
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
NEED PARKINSON COWAN - OVEN DOOR - GREEN -
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
Can only get low flame in oven
dirty orface or is it set for propane instead of nat gas
Dec 27, 2009 | Parkinson Cowan Kitchen Ranges
Main Oven will light and remain on, however there is no temp adjustment even after a time delay Model Parkinson Cowan SIG 454
Hi
The problem you have is this:
The FSD (Flame Safeguard Device) is faulty. This is what it does....
When you turn your oven on the FSD allows a small amount of gas through to the burner, the lit gas heats the FSD and says yay we have gas!, it then lets more gas through!
If it's broke it just keeps it on low flame.
You need to get a qualified Gas Engineer to look at it for you
I hope this helps
Steve :)
Jul 14, 2009 | Kitchen Ranges
Parkinson cowan sonata 55x gas cooker
When foods come out burned, soggy, or unevenly baked, it generally means heat isn't being distributed evenly throughout the oven, it's escaping out the door, or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven.
2) Check the door gasket, and, if necessary, replace it.
3) Be sure nothing is obstructing the vent.
4) Reposition the oven racks so baking pans aren't too close to the heat sources.
5) Check your baking pans. If they're dark, they may be burning your food. Reduce the temperature by 25 degrees Fahrenheit when baking in dark metal or glass pans.
You can also recalibrate the controls. If your oven has calibration right on the knob, you can calibrate the appliance as follows. If it doesn't, call an appliance repairperson. To adjust the thermostat's calibration:
1) Remove the oven temperature knob by pulling it off its shaft.
2) Notice the current setting, and then move the pointer in either direction to adjust its temperature slightly up or down. It's intentionally difficult to move the pointer on some models; if this is the case, you'll have to remove a couple of screws. Figure that moving it one notch will change the setting by 10 degrees Fahrenheit.
3) For more accurate calibration, call an appliance repairperson.
Do rate the solution i need it!!
Jun 17, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Will not ignite
have a parkinson cowan renown model RG60SS, about 12 years old. automatic ignition does not work - no sound or anything.. please help!!!!!
Dec 30, 2007 | Parkinson Cowan SG340 Gas Kitchen Range
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
262 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
