Question about VeriFone VX510
Reboot the machine has blocked and it says safety problem,reboot
Vacuum is not picking up dirt, dog hair, and lint! After 30 minutes use and I shut off machine it will not turn back on - machine is hot!
Blocked hose, filters, broken belt (If fitted) safety over temp device has operated turning the machine off. If it turns back on when it cools down, that gives you the answer. The motor could possibly be faulty as well.
Nov 19, 2016 | Vacuums
Whirlpool stylemaster 4217141 water won't stop filling the machine and it wont start agitating
drain machine and check the water level pressure switch air pipe
that's connected to it ,it's posably blocked stopping the switch from operating. safety disconnect from mains electrical supply before removing any covers.
Nov 13, 2016 | Whirlpool Washing Machines
Switching on the machine XEROX MODEL 6030 WIDE FORMAT an error appears '003-302 please reboot' after rebooting the machine the error still remains SOLUTION Required
Hi Shahab,
Have you looked inside the printer to see if you have any media or sensors blocked or torn media stuck inside.
Don't leave the lid open too long or your drum might get light shocked.
You need further investigation on this problem.
As the problem occurred several days ago I assume you might have it fixed by now.
Good Luck.
Apr 22, 2015 | Xerox Office Equipment & Supplies
Bosch dishwasher does not drain water and does not run
Bosch,. like many others have a "safe: cycle where the machine will always do a short pump out before it starts any cycle. If it fails to do a pump out even if there is no water in the machine, the machine will go into safety mode and will not allow a program to start. You will have to pull the machine out and check if the drain hose is blocked or kinked, and that the drain pump is not blocked or jammed. Toothpicks, bits of food and broken glass fragments are good for blocking / jamming dishwasher pumps.
Mar 09, 2015 | Bosch Integra 300 Series SHX33A05UC
Electrolux evf 10240 do not heating. Everything else is OK. New heater is in machine. What is the problem?
Over temperature safety thermostat maybe open circuit if fitted temperature control thermostat or thermistor faulty ,water level sensor tube blocked so circuit does not switch on without water level correct. Lastly broken wire somewhere
Apr 12, 2014 | Washing Machines
Bosch SHEM06UC/50 runs down to 1 but never finishes cycle.
Sounds like you either have a leak which has activated the flood safety in the base, you can check this by pulling the machine onto a towel and tipping the whole unit forward ie raise the back of the machine off the floor so it is pivoted on the front feet at approx 45 degrees, if water runs out from under the machine you have a leak (the machine may well start to work again now but you need to trace the leak or it will reoccur as soon as the safety is activated again). The other possibility is the pressure chamber or hose (pressure chamber to sump) is blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Mar 15, 2013 | Bosch Dishwashers
Machine won't spin out the water in the clothes,has to be wrung by hand..What would you think the part is that's holding this up?
Check the washer lid safety switch . Sounds like it is a simple switch for when you close the lid it allows to spin only when lid is closed. It is a safety switch for spinning to not operated if lid is open durring spinning cycle. It's maybe a 20 dollar part and easy install.
May 07, 2011 | Washing Machines
Gloria two group Astoria was shooting steam the other morning we turned it off what could this be from?
Where is the steam coming from, if its from the top, then the problem is the vent valve or the safety valve, if it is the safety then the pressure stat needs to be replaced because it might be damaged or blocked at the tube that connects it to the boiler.
Mar 12, 2011 | Astoria Argenta SAE-2 Espresso Machine
The machine is showing the brew unit is blocked but we have taken it out and cleaned it but this makes no difference.
Does the brew unit try to move at all? You can listen for the motor, or open the door panel and defeat the safety interlock while it's operating. (Be careful not to put a finger in there.) Then you can observe where the brew unit is getting stuck.
May 19, 2010 | Gaggia Syncrony Compact Digital Espresso...
VeriFone VX510 Logo
567 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
