Question about Ryobi Multi-Volt Battery Charger
Do Ryobi rechargable batteries fit other brand rechargers?
Do Ryobi rechargable batteries fit in any other brand of recharger (e.g., Dewalt, Milwakee, etc.)? I want to get an on-site radio/recharger, but Ryobi doens't make one and some of the others do.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
They dont fit at all
Posted on Jul 29, 2010
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Need to know what terminals to conncect a 12v charging system to a Dewalt 18v battery in order to recharge it. I know it is a three prong system and I am assuming that the small center ground is used for...
I do not recommend connecting anything but the factor charger to the battery. No 12v will not not charge an 18v battery.
They can BLOW UP if you apply too much current.
The correct charger can be found cheap. Look on craigs list under tools.
Good Luck
Feb 01, 2011 | Dewalt Drills
I need to buy a drill/driver for DIy at home, I am medium skilled handy. Do the batteries in the battery operated ones die if not used/recharged regularly. What are the medium to good avilable.
The battery tools are the way to go, the batteries last a couple years or more. I have a couple that are almost 5 years old. For the home and light construction I would go with the Ryobi 18 volt. The price is very good and they are very dependible. Think about a set (drill, circular saw, reciprocating saw, and flash light) they will all come in handy around the home and sets are cheeper. You can find them at Home Depot
Jan 19, 2011 | Dewalt Home Fencing
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
Sorry but does the dw911 xe type 1 radio charge the battery
Yes, the DeWalt radio will recharge the batteries, from the 12 Volt to 18 Volt versions. However, even with the radio plugged into an AC outlet, you have to either have the radio turned on, or have the unit in the AUX setting, in order for the batteries to get charged.
It typicaly takes about an hour +/- to fully charge a discharged battery. I normally don't put batteries directly into a charger right after they become discharged from being used in a tool, since they are still warm from use and charging them will generate more heat in the recharging
process.
Heat is the enemy of rechargeable batteries, so to get the longest working life out of your batteries, I'd let them cool down first, before recharging them, unless you absolutely need to use them right away, then go ahead and recharge them. If you can delay recharging them until they've cooled down, you'll get a more fuller recharge out of them.
Hope you find this Very Helpful and best regards!
Sep 30, 2009 | Dewalt Drills
HOW TO REPAIR YOUR RYOBI RECHARGABLE DRILL BATTERY
ryobi is the most inexpensive cordless brand, and they assume you will throw it out after it stops working so there is no repair support. sorry.
Sep 02, 2009 | Ryobi Multi-Volt Battery Charger
Reset DeWalt battiers using a mig weilder
I never heard of such a thing- messing with rechargeable batteries with home remedies can result in the battery melting or possibly exploding. Be very careful how you treat any rechargeable battery. Try rechargeing it twice in a row, letting it cool serveral minutes between charging. Heat is the death of rechargeable batteries.
Jun 22, 2009 | Drills
Ryobi cordless drill
sounds very much like the batterys we used to have ryobi drills but the batterys dont last now we use makita/dewalt/bosch
Oct 01, 2008 | Drills
Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Ryobi Multi-Volt Battery Charger Logo
851 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
