I have a hp pavilion dv5-1233se and when i turn on dont shows nothing on the screen but the light of the caps lock and num lock keep blinking , what should i do ??
  • 1 more comment
  • RUI MOREIRA
    RUI MOREIRA May 10, 2010
    Hi, i have donne all the procedures with the bat. and check with the external monitor but still the same the caps and num lock blinking and the lights above from the sound and media controls light on but still
  • RUI MOREIRA
    it keep blinking without pausing like every two seconds bouth
  • RUI MOREIRA
    thanks very much, you are a guru :)
  • 13,433 Answers
Hello
Lets start by removing the battery from the bottom of the laptop and then the power adapter / charger. Let the laptop be for 5 minutes, then hold down the power button for 15 seconds, then plug the laptop back to power, keep the battery out for now.
If the laptop power on and works, problem solved, you may reconnect the battery, if the problem comes back later in the future just repeat the above.
if this does not solve the problem then lets see...
When you turn on the laptop, do you get anything to flash on the screen? text for a short moment? Or is it completely silent? How about have you tried connecting a desktop computers display/monitor to the port on the side or on the back of the laptop - do you get picture on the desktop monitor? Is anything flashing on the screen? a Cursor?
Also Please take note of how many times the keys flash, it may indicate a error condition, please tell me the count, it will help in solving this issue.
Posted on May 10, 2010
  • Ekse May 10, 2010
    how many times do they blink? how many blinks until a pause?
    This document pertains to HP Notebook PCs with the HP Startup Support Environment.
    On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes.
    The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. There is a pause and the pattern repeats continuously at the end of the series of blinks until the error is resolved.
  • Ekse May 10, 2010
    Okay, looking at the HP code list, that would be Code 1
    CPU not functionalThe computer processor (Blink code 1) has stopped functioning properly. Contact HP for assistance.
    Unfortunately, the cpu is inside the laptop, it can be removed and replaced, but I would not recommend you to do this yourself, as the CPU is NOT cheap, if the issues remain after replacement, you would have wasted and considerable amount of money on the replacement part.
    It would be best to take the laptop to a repairer or a shop, IF it is outside of warranty, the repairer can test another CPU on the laptop so you won't spend money on parts unless needed.
    It seems that theres a fairly good chance of getting this fixed under 200 us $, I would take it in to a shop.
    if you are in warranty contact hp, they won't charge you for the repair.
    Again outside of warranty, best thing for you is to take it in to a repairer.
    Let me know if you have any questions or if you need anything else.
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
My laptop when I power on, shows a blank black screen and the caps and num lock lights are blinking and the fan is running.
Your hard drive has probably gone bad and it does not have a bootable device to use on start-up.
Mar 15, 2011 | HP Pavilion dv7-1245dx Notebook
My hp paviliOn tx2500 touchscreen laptop monitor will not turn on. The caps lock and numb lock lights flash on and off, and the blue lights around the screen work, and I can hear it turn on, however the...
cap lock & num lock flashes are an error codes
LEDs blink 1 timeCPUCPU not functionalLEDs blink 2 timesBIOSBIOS corruption failureLEDs blink 3 timesMemoryModule error not functionalLEDs blink 4 timesGraphicsGraphics controller not functionalLEDs blink 5 timesSystem boardGeneral system board failureLEDs blink 6 timesBIOSBIOS authentication failure
Jan 03, 2011 | HP Pavilion tx2500z Tablet PC
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Hp compaq powering and nog display what do i do to
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
I have an hp pavilion dv4- 1430 us that won't turn on
I had the same problem with my hp pavilion dv4 1430 and to fix it I just took out the battery and unplugged it from the power adapter and pushed the power button and waited for a few minutes I put it all back together and started it up and the screen turns right back on.
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
