Question about Acer AL1916W 19" LCD Monitor
The monitor is stuck on auto adjustment and would not change
I have tried to to overwrite this manually but it would not allow me to. I tried switching it off and on, but the computer starts up then this "message in a blue box "Auto Adjustment" flickers on the montoring without cahnging
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 74 Answers
Look if the "auto adjus"t button isn't stuck.
Posted on May 10, 2010
Asus 19inch LCD monitor keeps auto adjusting and turn off after 2secs. . i do reset it . . nothing happens. .it keeps auto adjusting itself repeatedly . . pls help me
The Auto knob maybe mechanically stuck or the internal switch may be defective. Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement. Do rate the solution.
Samir
Feb 07, 2011 | ASUS 19 Inch Sxga 1280X1024, 5MS,...
My monitor keeps saying auto adjustment in progress
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature. I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
May 11, 2010 | HP w2207 Monitor
My westinghouse monitor won't align on the screen. i have tried auto adjust already and it is still missaligned.
Ok, with the Auto adjust, but have you actually tried the buttons that actually manually adjust the screen, size, placement, width, height etc, This will allow you complete control over all aspects of your monitor. You usually select, menu, then step through with one button, and change up, down, side to side, with the left & right buttons.
Mar 02, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor auto adjust problem
It sounds as though the autoadjust button (switch) has stuck. Try tapping it a few times (the button, that is!)
Sep 24, 2009 | Dell E173FP 17" LCD Monitor
My hp w1907 monitor is constantly auto adjusting every 1 or 2 seconds. Make it stop.
Good morning! Auto adjustment occurs when resolution or refresh rate of the display changes. Check your display setings in OS. Set them properly according to product operations manual. Update your display adapters driver. Also check your VGA card or motherboard display port & try using a different cable. try pluging the monitor to a different computer or plug in a different monitor with your motherboard or VGA cards display port. best regards
May 03, 2009 | HP w1907 LCD Monitor
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Samsung syncmaster 720 n
Is the auto adjust button stuck?
May 09, 2008 | Samsung SyncMaster 720N Monitor
Auto adjusting
Try wiggling the auto adjust button on the front of the monitor, it sounds like the button is jammed against the switch causing it to auto adjust over and over.
Mar 21, 2008 | Gateway FPD2275W LCD Monitor
Monitor message
hello this is nichu ,your monitor is not supporting your cpu .hence you are getting the message "processing auto config message from screen display".either you have to change your monitor or you have to change your cpu.next time while purchasing the pc get the help your hardware vendor to check out the compatibility
Nov 04, 2007 | Gateway FPD1530 15" TFT LCD Flat Panel...
Acer AL1916W 19" LCD Monitor Logo
287 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
