Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Electric Heating Element
I checked the continuity across the heating element (Red and Red/white stripe wires). There is no continuity; therefore, I assume that the element is shorted. I was unable to take out the complete heating element housing assembly after removing 2 screws that hold the element in front. I jiggled and it moves but does not come out of the rear hold. Please suggest how to remove this element housing and replace it with a new element. Thermal switches mounted below the element housing show continuity. I would appreciate your help to save a service call from appliance repair company.
Thanks
  • 5,911 Answers
No continuity would mean the element is OPEN, or showing an infinite resistance reading. If the element were SHORTED, it would read 0 ohms. These elements are supposed to read 9 to 13 ohms if good. Double check and make sure have your meter scale set correctly. You should be taking resistance checks on the lowest scale of Rx1.
If you have confirmed the element is defective, and the model dryer is correct, the element should pull out of the heater box by removing two screws on the left hand side of the box. You will need to remove the thermal cut-out (TCO) and hi-limit thermostat in order to accommodate removal of the element. These are the two components that are mounted on the side of the heater box. You leave the wires connected, and simply remove any mounting screws that hold them in place. This will keep the element from coming out of the heater box.
If these instructions are not clear, please post back with your MODEL NUMBER so I can understand how your dryer is configured.
If your dryer runs, but does NOT heat, the following two links can give you some added advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
Read through the information I provided and, if you have any questions. I'm assuming this is a Whirlpool Electric Dryer, because of the illustration you posted the question under. I hope you find this information is helpful.
If you would like some added advice that can help you in the future, Repairclinic.com has a repair manual that you can purchase that you can to help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on May 10, 2010
I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-head screw.
Note:
The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Apr 01, 2011 | Whirlpool Dryers
Red light's on... but no hot water!
HI,
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Goodluck,
Please don't forget to rate the solution
Apr 05, 2008 | Braun WK600 Cordless Electric Kettle
We have a 5 year old Roper electric dryer that started to fail in heating the clothes. I've checked the electric plug at the wall, and have 240 volts. I've checked the thermal fuse, and the continuity is...
You can test the stats they should read short circuit/ normally closed, you could short them out for 10 secs to check not good idea to leave permanantly as would cause safety issue element if one section two wires plus an earth to it should read about 30 0dd ohms
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer not heating up checked heating element have continuity arcroos coil connectors
Check the thermostats. Unplug one wire and test for continuity across the thermostat terminals.
Jan 03, 2010 | Whirlpool Dryers
Heating is not hot
Either the wires to the heating element have burned out, the heating element is shot, or the temperature sensor is shot. Unplug the dryer and check the heating element for continuity, check for burned wires between the relay and the coils, and check for continuity across the cold temperature sensor. Replace any defective parts.
Dec 01, 2009 | Frigidaire GLER341A Electric Dryer
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Dryer not heating...everything seems OK
Y'ou are zeroing in on your problem. Read the info below and hopefully you will have your answer:
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Mar 11, 2009 | Kenmore 62602 Electric Dryer
Dryer heating element
To the heating element goes Red and Red with White.
To the Hi-limit thermostat goes Red with White and Black.
To the Thermal cut-off goes Black and Red.
Dec 11, 2008 | Whirlpool GEW9250 Electric Dryer
Hot Water Heater Trouble
(1)Have the unit check for electric voltage to the element
If voltage going to the element and no heating
(2)Your heating element may be defective.
(3) Have it replace by qualified personel
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
166 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
